跳转到主内容
加入维修社区 - 创建账户
Microsoft Surface Book Keyboard USB Port Replacement
你所需要的
    1. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 步骤 1 中的图像 1,3 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 步骤 1 中的图像 2,3 Microsoft Surface Book Keyboard USB Port Replacement, Remove the display with the Detach button: 步骤 1 中的图像 3,3
      • In order for the keyboard to be detached with the Detach buttons, both batteries must be charged above 10 percent. If your device doesn't power on and you can't use the Detach buttons, skip to the next step.
      • Press and hold the Detach button on the keyboard.
      • Once pressed, the Detach button it will light up red. After a second, it’ll turn green and you’ll hear an audible clicking sound.
      • Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
      • Remove the display.
      询问修复机器人
      添加评论
    2. Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: 步骤 2 中的图像 1,2 Microsoft Surface Book Keyboard USB Port Replacement, Manually detach the display: 步骤 2 中的图像 2,2
      • The next six steps show how to detach the display manually if you’re unable to power on the Surface Book.
      • Flip open the display as far as it will go.
      • Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
      询问修复机器人
      添加评论
    3. Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: 步骤 3 中的图像 1,2 Microsoft Surface Book Keyboard USB Port Replacement, Bend a paper clip: 步骤 3 中的图像 2,2
      • Straighten out one section of a paper clip.
      询问修复机器人
      添加评论
    4. Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 步骤 4 中的图像 1,3 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 步骤 4 中的图像 2,3 Microsoft Surface Book Keyboard USB Port Replacement, Push the paper clip into the hole: 步骤 4 中的图像 3,3
      • The Surface Book has an internal lever arm mechanism that can be manually actuated through an access hole in the vents on side of the display.
      • Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
      添加评论
    5. Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 步骤 5 中的图像 1,3 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 步骤 5 中的图像 2,3 Microsoft Surface Book Keyboard USB Port Replacement, Release the mechanism: 步骤 5 中的图像 3,3
      • Firmly push the paper clip into the hole.
      • This may take a considerable amount of force.
      • Once the internal lever arm is fully depressed, you can disconnect the display.
      • Pull the base away from the display to detach it.
      • If you are unable to detach the display from the base on this side, release pressure on the paper clip and try again.
      添加评论
    6. Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 步骤 6 中的图像 1,3 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 步骤 6 中的图像 2,3 Microsoft Surface Book Keyboard USB Port Replacement, Detach the second side: 步骤 6 中的图像 3,3
      • The magnetic connections are prone to snap back into place, so hold the two halves apart.
      • With one side detached, pull firmly to pivot the display out to disconnect the second side.
      • If the magnetic connection feels extra strong and the display won't detach on the second side, keep the detached side separated with a spudger, pen, or pencil, and repeat the paper clip process on the other side of the display.
      询问修复机器人
      添加评论
    7. Microsoft Surface Book Keyboard USB Port Replacement, Remove the display: 步骤 7 中的图像 1,1
      • Completely power down your Surface Book before opening it up for any repairs.
      询问修复机器人
      添加评论
    1. Microsoft Surface Book Keyboard USB Port Replacement, Back Panel: 步骤 8 中的图像 1,1
      • Flip the keyboard over so you can see the back panel.
      添加评论
    2. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 9 中的图像 1,2 Microsoft Surface Book Keyboard USB Port Replacement: 步骤 9 中的图像 2,2
      • Insert the plastic opening tool in the crevice between the panel and the keyboard.
      • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
      • The panel is glued down on the inside so this may require some force to lift away the panel.
      • Continue to lift until the panel is completely separated from the keyboard.
      • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
      询问修复机器人
      添加评论
    3. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 10 中的图像 1,1
      • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
      询问修复机器人
      添加评论
    1. Microsoft Surface Book Keyboard USB Port Replacement, USB Port: 步骤 11 中的图像 1,1
      • Orient your keyboard with the internals facing up and the USB Port on the right.
      询问修复机器人
      添加评论
    2. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 12 中的图像 1,1
      • Use a plastic opening tool and remove the tab from the USB board
      询问修复机器人
      添加评论
    3. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 13 中的图像 1,2 Microsoft Surface Book Keyboard USB Port Replacement: 步骤 13 中的图像 2,2
      • Lift up the black and gold wires and find the screw hidden there.
      • Use the T3 Torx Screwdriver and remove the four mm screw.
      询问修复机器人
      添加评论
    4. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 14 中的图像 1,1
      • Use the T3 Torx Screwdriver to remove the remaining three 4 mm screws.
      询问修复机器人
      添加评论
    5. Microsoft Surface Book Keyboard USB Port Replacement: 步骤 15 中的图像 1,2 Microsoft Surface Book Keyboard USB Port Replacement: 步骤 15 中的图像 2,2
      • Wiggle the USB Port board away from the keyboard.
      • This may require some force.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Cal Poly, Team 20-3, Livingston Fall 2016 Cal Poly, Team 20-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G3
4 名成员
创作了54篇指南
5指南评论
But how do you remove and re-attach the ribbon cables without damaging them? Seems like an important detail that is left out.
Brandon M - 回复 分享
How do you re-glue the bottom cover back on?
Mike Guarino - 回复 分享
Where do you get the replacement USB board? Is there’s a part number for it that I can look up?
wheetcracker - 回复 分享
Can the same be done for the type c port
Pavan Kumar - 回复 分享
There are quite a few questions raised Tunnel Rush. Maybe I missed a few details in the manual.
stevens gomez - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 70
总计 7,142
