跳转到主内容
加入维修社区 - 创建账户
Microsoft Kinect Tilt Motor Replacement
你所需要的
  1. Microsoft Kinect Tilt Motor Replacement, Tilt Motor: 步骤 1 中的图像 1,1
    • Pull the rubber backing off the base of the Kinect.
    • If the adhesive attaching the rubber backing and the base doesn't come off with the rubber backing, remove the adhesive as well.
    • If the adhesive comes off separately, you may some type of adhesive to reattach the rubber backing.
    询问修复机器人
    添加评论
  2. Microsoft Kinect Tilt Motor Replacement: 步骤 2 中的图像 1,2 Microsoft Kinect Tilt Motor Replacement: 步骤 2 中的图像 2,2
    • Unscrew the four 7mm T6 Torx screws.
    • Pull off the base to reveal the inner case.
    询问修复机器人
    添加评论
  3. Microsoft Kinect Tilt Motor Replacement: 步骤 3 中的图像 1,3 Microsoft Kinect Tilt Motor Replacement: 步骤 3 中的图像 2,3 Microsoft Kinect Tilt Motor Replacement: 步骤 3 中的图像 3,3
    • Unscrew the four 5mm #0 Phillip screws.
    • These screws strip easily.
    • Remove the metal plate to reveal the motor and gears.
    • Disconnect the connector to separate the plate from the Kinect.
    添加评论
  4. Microsoft Kinect Tilt Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the three gears on top of the motor, starting with the center gear.
    询问修复机器人
    添加评论
  5. Microsoft Kinect Tilt Motor Replacement: 步骤 5 中的图像 1,2 Microsoft Kinect Tilt Motor Replacement: 步骤 5 中的图像 2,2
    • Unscrew the four 5mm #00 Phillip screws.
    • Remove the motor from the plate to replace.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
Daniel
于04/20/15注册
395 声望
撰写一个指南
团队
Cal Poly, Team 14-7, Amido Spring 2015 Cal Poly, Team 14-7, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G7
4 名成员
创作了6篇指南
2指南评论
Be careful not to lose the spring & washer ! ( It’s also missing a step showing where the brass washer goes )https://www.zdnet.com/pictures/microsoft...
Bantum Works - 回复 分享
So far the isn’t a mention replacement of the plastic “post” that the tilt motor and the upper sensor unit are joined at. Mine broke (that’s what happens when you get a “free Xbox 360” at a neighborhood moving sale.) I couldn’t get the base plate apart as my T5 torx bit is trashed. So, my solution?…epoxy the heck out of the post as it’s only purpose is to hold the two units of the Kinect together. So far it worked!
David C - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 27
过去 30 天: 104
总计 5,952
