跳转到主内容
加入维修社区 - 创建账户
Microsoft Kinect Microphone Panel Replacement
你所需要的
    1. Microsoft Kinect Microphone Panel Replacement, Case: 步骤 1 中的图像 1,3 Microsoft Kinect Microphone Panel Replacement, Case: 步骤 1 中的图像 2,3 Microsoft Kinect Microphone Panel Replacement, Case: 步骤 1 中的图像 3,3
      • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
      • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
      • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
      • Do not overheat as it may cause damage to the internal components.
      询问修复机器人
      添加评论
    2. Microsoft Kinect Microphone Panel Replacement: 步骤 2 中的图像 1,1
      • Unscrew the six 12mm T10 Torx screws.
      询问修复机器人
      添加评论
    3. Microsoft Kinect Microphone Panel Replacement: 步骤 3 中的图像 1,3 Microsoft Kinect Microphone Panel Replacement: 步骤 3 中的图像 2,3 Microsoft Kinect Microphone Panel Replacement: 步骤 3 中的图像 3,3
      • Remove the top portion of the case from the rest of the body.
      • Detach the side portions of the case from the body.
      • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
      • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
      询问修复机器人
      添加评论
    4. Microsoft Kinect Microphone Panel Replacement: 步骤 4 中的图像 1,1
      • Remove the bottom portion of the case by sliding it out from under the body.
      • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
      询问修复机器人
      添加评论
    5. Microsoft Kinect Microphone Panel Replacement: 步骤 5 中的图像 1,2 Microsoft Kinect Microphone Panel Replacement: 步骤 5 中的图像 2,2
      • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
      询问修复机器人
      添加评论
    6. Microsoft Kinect Microphone Panel Replacement: 步骤 6 中的图像 1,2 Microsoft Kinect Microphone Panel Replacement: 步骤 6 中的图像 2,2
      • Remove the front portion of the case containing the lens coverings for the cameras.
      • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
      询问修复机器人
      添加评论
    1. Microsoft Kinect Microphone Panel Replacement, Microphone Panel: 步骤 7 中的图像 1,1
      • Unplug the microphone from motherboard.
      询问修复机器人
      添加评论
    2. Microsoft Kinect Microphone Panel Replacement: 步骤 8 中的图像 1,1
      • Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
      • Pull the cable out carefully to avoid damage.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Nick Carlucci
于04/26/15注册
394 声望
创作了3篇指南
团队
Cal Poly, Team 14-7, Amido Spring 2015 Cal Poly, Team 14-7, Amido Spring 2015 的会员
CPSU-AMIDO-S15S14G7
4 名成员
创作了61篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 44
总计 1,655
