跳转到主内容
加入维修社区 - 创建账户
Microsoft Band Wrist Clasp Replacement
你所需要的
    1. Microsoft Band Wrist Clasp Replacement, Wrist Clasp: 步骤 1 中的图像 1,1
      • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
      询问修复机器人
      添加评论
    2. Microsoft Band Wrist Clasp Replacement: 步骤 2 中的图像 1,1
      • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
      询问修复机器人
      添加评论
    3. Microsoft Band Wrist Clasp Replacement: 步骤 3 中的图像 1,1
      • Pull the two securing pins out of the rubberized part of the band.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Chad Steese
于02/02/15注册
259 声望
创作了2篇指南
团队
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G34
4 名成员
创作了30篇指南
3指南评论
where can I purchase the replacement part
jeepgirlutah - 回复 分享
+1 for Jeepgirlutah
Guide is not for replacing clasp, it just is for removing it... It has no use to remove the clasp while it is still properly attached.
The real question is on how to replace it when it is broken (like ripped off like mine did).
dopplerdefekt - 回复 分享
I am a broken the strap where it holds the small piece of metal. I need a new belt spare? thanks and regards
Xavier Ribas Roig - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 39
总计 5,510
