跳转到主内容
加入维修社区 - 创建账户
Microsoft Band Battery Replacement
你所需要的
    1. Microsoft Band Battery Replacement, Battery: 步骤 1 中的图像 1,1
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      询问修复机器人
      添加评论
    2. Microsoft Band Battery Replacement: 步骤 2 中的图像 1,1
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      询问修复机器人
      添加评论
    3. Microsoft Band Battery Replacement: 步骤 3 中的图像 1,1
      • Gently pry up one edge of the battery with the plastic spudger.
      询问修复机器人
      添加评论
    4. Microsoft Band Battery Replacement: 步骤 4 中的图像 1,1
      • Remove battery from its compartment with your fingers.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 17-34, Amido Winter 2015 Cal Poly, Team 17-34, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G34
4 名成员
创作了12篇指南
5指南评论
where can i buy the battery?
chirac - 回复 分享
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - 回复 分享
Will this be dangerous?
Rei zzstu Shiozawa - 回复 分享
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - 回复 分享
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 50
总计 12,600
