跳转到主内容
MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement
你所需要的
  1. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 步骤 1 中的图像 1,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 步骤 1 中的图像 2,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Determine the unloader assembly: 步骤 1 中的图像 3,3
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 步骤 2 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 步骤 2 中的图像 2,2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: 步骤 3 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the hose clamp: 步骤 3 中的图像 2,2
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: 步骤 4 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Disconnect the return hose: 步骤 4 中的图像 2,2
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Position the support block: 步骤 5 中的图像 1,1
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: 步骤 6 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Re-position the return elbow: 步骤 6 中的图像 2,2
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: 步骤 7 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the filter: 步骤 7 中的图像 2,2
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the filter: 步骤 8 中的图像 1,1
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: 步骤 9 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the input elbow: 步骤 9 中的图像 2,2
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the input elbow: 步骤 10 中的图像 1,1
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: 步骤 11 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output assembly: 步骤 11 中的图像 2,2
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the output assembly: 步骤 12 中的图像 1,1
    • Remove the output assembly.
  13. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Clamp the output assembly: 步骤 13 中的图像 1,1
    • You will need to remove the remaining fittings from the output assembly in order to replace the unloader.
    • Secure the output assembly in a large vise.
  14. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 步骤 14 中的图像 1,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 步骤 14 中的图像 2,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the output elbow: 步骤 14 中的图像 3,3
    • Hold the outlet fitting in place with a 15/16" or large adjustable wrench.
    • Use a 3/4" or adjustable wrench to loosen and unscrew the output elbow from the outlet fitting.
  15. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement: 步骤 15 中的图像 1,1
    • Remove the output elbow with the quick-connect socket attached to it.
  16. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: 步骤 16 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the coupling nipple: 步骤 16 中的图像 2,2
    • Use a 3/4" or adjustable wrench to loosen and unscrew the coupling nipple from the unloader.
  17. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the coupling nipple: 步骤 17 中的图像 1,1
    • Remove the coupling nipple.
  18. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: 步骤 18 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Loosen the return hose nipple: 步骤 18 中的图像 2,2
    • Use a 11/16" or adjustable wrench to loosen and unscrew the return hose nipple from the unloader.
    • You do not need to disconnect the hose from the nipple.
  19. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Remove the return hose: 步骤 19 中的图像 1,1
    • Remove the return hose nipple with the hose attached.
  20. MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 步骤 20 中的图像 1,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 步骤 20 中的图像 2,3 MiTM Pressure Washers CA2703HDHB1 2017 Unloader Replacement, Check for plug placement: 步骤 20 中的图像 3,3
    • Only the unloader assembly remains.
    • Compare the original unloader with the replacement part. The replacement part may have a plug installed in the wrong port.
    • Use an 8 mm (5/16" OK) hex key to remove and re-install the plug into the correct port.
结论
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
4等其他人完成本指南。
Arthur Shi
于01/03/18注册
254,217 声望
创作了529篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,303篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 50
总计 1,087
