跳转到主内容
MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement
你所需要的
  1. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter bolts: 步骤 1 中的图像 1,1
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Use a 10 mm socket to remove the three 24 mm long bolts.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement, Remove the recoil starter assembly: 步骤 2 中的图像 1,1
    • Remove the recoil starter assembly.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: 步骤 3 中的图像 1,2 MiTM Pressure Washers CA2703HDHB1 2017 Recoil Starter Replacement: 步骤 3 中的图像 2,2
    • If you are replacing the assembly with a non-OEM part, you may also have to replace the starter cap.
    • Remove the 3/4" bolt with a deep socket.
    • This bolt can be very difficult to remove. Use the hook as a bracing point to keep the starter cap from rotating.
结论
另外一个人完成了本指南。
Arthur Shi
于01/03/18注册
252,854 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 676
