跳转到主内容
Meta Quest 2 Controller Faceplate prereq
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Meta Quest 2 Controller Faceplate prereq, Remove the battery cover: 步骤 1 中的图像 1,3 Meta Quest 2 Controller Faceplate prereq, Remove the battery cover: 步骤 1 中的图像 2,3 Meta Quest 2 Controller Faceplate prereq, Remove the battery cover: 步骤 1 中的图像 3,3
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Faceplate prereq, Loosen the faceplate adhesive: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
  3. Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: 步骤 3 中的图像 1,3 Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: 步骤 3 中的图像 2,3 Meta Quest 2 Controller Faceplate prereq, Loosen the controller faceplate: 步骤 3 中的图像 3,3
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  4. Meta Quest 2 Controller Faceplate prereq: 步骤 4 中的图像 1,2 Meta Quest 2 Controller Faceplate prereq: 步骤 4 中的图像 2,2
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  5. Meta Quest 2 Controller Faceplate prereq: 步骤 5 中的图像 1,2 Meta Quest 2 Controller Faceplate prereq: 步骤 5 中的图像 2,2
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  6. Meta Quest 2 Controller Faceplate prereq, Remove the faceplate: 步骤 6 中的图像 1,3 Meta Quest 2 Controller Faceplate prereq, Remove the faceplate: 步骤 6 中的图像 2,3 Meta Quest 2 Controller Faceplate prereq, Remove the faceplate: 步骤 6 中的图像 3,3
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
结论
Arthur Shi
于01/03/18注册
313,508 声望
创作了729篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,752篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 87
