跳转到主内容
加入维修社区 - 创建账户
Merch Source Projector Entertainment II Outer Lens Replacement
你所需要的
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: 步骤 1 中的图像 1,2 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Casing: 步骤 1 中的图像 2,2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      询问修复机器人
      添加评论
    2. Merch Source Projector Entertainment II Outer Lens Replacement: 步骤 2 中的图像 1,1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      询问修复机器人
      添加评论
    3. Merch Source Projector Entertainment II Outer Lens Replacement: 步骤 3 中的图像 1,2 Merch Source Projector Entertainment II Outer Lens Replacement: 步骤 3 中的图像 2,2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      询问修复机器人
      添加评论
    1. Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: 步骤 4 中的图像 1,2 Merch Source Projector Entertainment II Outer Lens Replacement, Ribbon Cable Detachment: 步骤 4 中的图像 2,2
      • Use the plastic opening tool to gently disengage the black clip housing from the ribbon cable.
      • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
      • Once the housing is disengaged, the ribbon cable should slide out easily. Do not pull too hard on the ribbon cable as it is very fragile.
      询问修复机器人
      添加评论
    2. Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 步骤 5 中的图像 1,3 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 步骤 5 中的图像 2,3 Merch Source Projector Entertainment II Outer Lens Replacement, Motherboard Detachment: 步骤 5 中的图像 3,3
      • Unscrew the three 7 mm screws from the motherboard with the Phillips #0 screw driver.
      • Once loose, lift the motherboard off of the lens casing, and move it away from the workspace.
      • Be sure not to damage any of the wires atached to the motherboard.
      询问修复机器人
      添加评论
    3. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 步骤 6 中的图像 1,3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 步骤 6 中的图像 2,3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Detachment: 步骤 6 中的图像 3,3
      • Unscrew the four 15mm Phillips screws using the Phillips #0 screw driver.
      • Unscrew the two 12mm Phillips screws using the Phillips #0 screw driver.
      • Gently remove the entire lens casing from its position.
      询问修复机器人
      添加评论
    4. Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 步骤 7 中的图像 1,3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 步骤 7 中的图像 2,3 Merch Source Projector Entertainment II Outer Lens Replacement, Lens Casing Seperation: 步骤 7 中的图像 3,3
      • Using the plastic opening tool, slightly separate the casing holding the large lens in place.
      • Separate the casing completely from the inner lens using your hands.
      • This should release the outer lens and it's immediate casing.
      • As you separate the outer casing, the lens and digital display box may fall out of their encasement.
      • Although there are threads connecting the outer lens casing and the inner lens casing, do not be fooled. The outer lens casing cannot be disconnected by unscrewing it.
      询问修复机器人
      添加评论
    5. Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 步骤 8 中的图像 1,3 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 步骤 8 中的图像 2,3 Merch Source Projector Entertainment II Outer Lens Replacement, Outer Lens Casing Seperation: 步骤 8 中的图像 3,3
      • Unscrew the four 8mm Phillips screws at the base of the outer lens casing using the Phillips #0 screw driver.
      • Separate the white outer casing from the black outer casing.
      询问修复机器人
      添加评论
    6. Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: 步骤 9 中的图像 1,2 Merch Source Projector Entertainment II Outer Lens Replacement, Final Outer Lens Removal: 步骤 9 中的图像 2,2
      • Using your finger, gently push the lens out of its white encasement.
      • The outer lens is now free and ready for replacement.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Stephanie
于01/08/15注册
282 声望
创作了3篇指南
团队
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G3
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 37
总计 3,622
