跳转到主内容
加入维修社区 - 创建账户
Merch Source Projector Entertainment II Light Bulb Replacement
你所需要的
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: 步骤 1 中的图像 1,2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: 步骤 1 中的图像 2,2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: 步骤 2 中的图像 1,1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: 步骤 3 中的图像 1,2 Merch Source Projector Entertainment II Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 步骤 4 中的图像 1,3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 步骤 4 中的图像 2,3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: 步骤 4 中的图像 3,3
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: 步骤 5 中的图像 1,2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: 步骤 5 中的图像 2,2
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
结论
另外一个人完成了本指南。
Stephanie
于01/08/15注册
282 声望
创作了3篇指南
团队
Cal Poly, Team 18-3, Maness Winter 2015 Cal Poly, Team 18-3, Maness Winter 2015 的会员
CPSU-MANESS-W15S18G3
3 名成员
创作了4篇指南
1指南评论
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 63
总计 2,535
