跳转到主内容
加入维修社区 - 创建账户
Marshall Stanmore II Tweeter Assembly Replacement
你所需要的
  1. Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: 步骤 1 中的图像 1,2 Marshall Stanmore II Tweeter Assembly Replacement, Rear Panel: 步骤 1 中的图像 2,2
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
    询问修复机器人
    添加评论
  2. Marshall Stanmore II Tweeter Assembly Replacement: 步骤 2 中的图像 1,2 Marshall Stanmore II Tweeter Assembly Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
    询问修复机器人
    添加评论
  3. Marshall Stanmore II Tweeter Assembly Replacement: 步骤 3 中的图像 1,2 Marshall Stanmore II Tweeter Assembly Replacement: 步骤 3 中的图像 2,2
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
    询问修复机器人
    添加评论
  4. Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: 步骤 4 中的图像 1,2 Marshall Stanmore II Tweeter Assembly Replacement, Tweeter Assembly: 步骤 4 中的图像 2,2
    • Carefully pull back the translucent plastic sheathing on the two silver tweeter connectors.
    询问修复机器人
    添加评论
  5. Marshall Stanmore II Tweeter Assembly Replacement: 步骤 5 中的图像 1,3 Marshall Stanmore II Tweeter Assembly Replacement: 步骤 5 中的图像 2,3 Marshall Stanmore II Tweeter Assembly Replacement: 步骤 5 中的图像 3,3
    • Using your fingernail or tweezers, apply precise pressure to the small latch in the middle of the connector and gently pull upwards to disconnect the connector.
    • Repeat for the second connector.
    询问修复机器人
    添加评论
  6. Marshall Stanmore II Tweeter Assembly Replacement: 步骤 6 中的图像 1,2 Marshall Stanmore II Tweeter Assembly Replacement: 步骤 6 中的图像 2,2
    • Use a Torx T20 screwdriver to remove the three 20.5 mm screws that secure the tweeter.
    • Lift the tweeter assembly from its housing.
    询问修复机器人
    添加评论
  7. Marshall Stanmore II Tweeter Assembly Replacement: 步骤 7 中的图像 1,1
    • The felt seal is removable. If there is no seal on the tweeter, it may be stuck to the cutout on the speaker frame.
    • Repeat steps 4-6 to remove the second tweeter if necessary.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
1指南评论
Do you know the tweeter spec? Or similar brand to install?
Leonardo Hernández - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 44
总计 802
