跳转到主内容
加入维修社区 - 创建账户
Marshall Stanmore II Subwoofer Assembly Replacement
你所需要的
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: 步骤 1 中的图像 1,2 Marshall Stanmore II Subwoofer Assembly Replacement, Rear Panel: 步骤 1 中的图像 2,2
      • Turn off the device and unplug the cable from the wall and the speaker.
      • Lay the speaker with the back panel facing up on a flat, stable work surface.
      询问修复机器人
      添加评论
    2. Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 2 中的图像 1,2 Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 2 中的图像 2,2
      • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
      询问修复机器人
      添加评论
    3. Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 3 中的图像 1,2 Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 3 中的图像 2,2
      • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
      • Do not attempt to fully remove the panel, as this will damage the connections inside.
      询问修复机器人
      添加评论
    1. Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 步骤 4 中的图像 1,3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 步骤 4 中的图像 2,3 Marshall Stanmore II Subwoofer Assembly Replacement, Subwoofer Assembly: 步骤 4 中的图像 3,3
      • Pull back the clear sheaths on the end of each wire to expose the terminals.
      • Using a pair of tweezers, or your fingernail, depress the small latch and gently pull the wire off of the metal tabs.
      • Failure to press the latch while pulling could damage the subwoofer and/or wires.
      询问修复机器人
      添加评论
    2. Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 5 中的图像 1,1
      • Remove the six 20.5 mm T20 Torx screws that secure the subwoofer to the housing.
      • The subwoofer assembly contains a very strong magnet, so the screwdriver and screws may occasionally stick to the side of the assembly.
      询问修复机器人
      添加评论
    3. Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 6 中的图像 1,1
      • Carefully lift the subwoofer assembly away from the housing.
      询问修复机器人
      添加评论
    4. Marshall Stanmore II Subwoofer Assembly Replacement: 步骤 7 中的图像 1,1
      • Optional: Inspect the felt gasket on the speaker frame for any tears or foreign material.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 65
总计 1,386
