跳转到主内容
加入维修社区 - 创建账户
Marshall Emberton Button Replacement
你所需要的
  1. Marshall Emberton Button Replacement, Button: 步骤 1 中的图像 1,1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    询问修复机器人
    添加评论
  2. Marshall Emberton Button Replacement: 步骤 2 中的图像 1,1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    询问修复机器人
    添加评论
  3. Marshall Emberton Button Replacement: 步骤 3 中的图像 1,1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    添加评论
  4. Marshall Emberton Button Replacement: 步骤 4 中的图像 1,1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    询问修复机器人
    添加评论
  5. Marshall Emberton Button Replacement: 步骤 5 中的图像 1,1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Asia Baldwin
于09/26/22注册
781 声望
创作了5篇指南
团队
CSU Los Angeles, Team 5-1, Adachi Fall 2022 CSU Los Angeles, Team 5-1, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S5G1
5 名成员
创作了12篇指南
4指南评论
where can i find a replacement button
MANU 1907 - 回复 分享
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - 回复 分享
yes, i confirme !!!
Mallet Jp - 回复 分享
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 175
总计 4,428
