跳转到主内容
加入维修社区 - 创建账户
Marshal Woburn Top Control Panel Replacement
你所需要的
    1. Marshal Woburn Top Control Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Marshal Woburn Top Control Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
      • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
      • On a flat surface, orient the device so that the front grille is facing downward.
      • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
      • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    2. Marshal Woburn Top Control Panel Replacement: 步骤 2 中的图像 1,2 Marshal Woburn Top Control Panel Replacement: 步骤 2 中的图像 2,2
      • Lift the back input board slightly above the back panel.
      • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
      • Fully slide the input board through the back panel and set it down gently inside the speaker.
      询问修复机器人
      添加评论
    3. Marshal Woburn Top Control Panel Replacement: 步骤 3 中的图像 1,1
      • Grab the panel by the large hole and lift one side until you can fit your hand under.
      • Use your hand to fully remove the back panel from the rest of the frame.
      询问修复机器人
      添加评论
    1. Marshal Woburn Top Control Panel Replacement, I/O Board: 步骤 4 中的图像 1,1
      • Disconnect the 5 wires circled in red from the back input board.
      • Grip and pull the connectors, not the wires.
      • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
      询问修复机器人
      添加评论
    2. Marshal Woburn Top Control Panel Replacement: 步骤 5 中的图像 1,2 Marshal Woburn Top Control Panel Replacement: 步骤 5 中的图像 2,2
      • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
      • Remove the power input from the back side of the panel.
      询问修复机器人
      添加评论
    3. Marshal Woburn Top Control Panel Replacement: 步骤 6 中的图像 1,1
      • Completely remove the I/O board and the attached plate.
      询问修复机器人
      添加评论
    1. Marshal Woburn Top Control Panel Replacement, Top Control Panel: 步骤 7 中的图像 1,1
      • Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
      询问修复机器人
      添加评论
    2. Marshal Woburn Top Control Panel Replacement: 步骤 8 中的图像 1,1
      • From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
      • On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
NateP
于11/01/23注册
284 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 的会员
UMASSD-GULBRANDSEN-F23S2G4
3 名成员
创作了18篇指南
1指南评论
Hi. The on off switch has broken on my Woburn 2. Any ideas how to replace it and where I could buy a new switch? Thank you.
mathew jones - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 1,066
