跳转到主内容
Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement
你所需要的
  1. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the sprocket guard plate: 步骤 1 中的图像 1,1
    • Use a 13 mm socket to remove the two nuts securing the sprocket guard plate.
  2. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 2 中的图像 1,1
    • Remove the sprocket guard plate.
  3. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain and guide bar: 步骤 3 中的图像 1,1
    • If the chainsaw has a chain and guide bar installed, follow the manufacturer's instructions and remove them before proceeding.
    • During reassembly, if you are reinstalling the chain and guide bar, follow the manufacturers instructions on proper chain tensioning techniques.
  4. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the chain brake cover: 步骤 4 中的图像 1,1
    • Remove the four 12 mm long T27 screws securing the chain brake cover.
  5. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 5 中的图像 1,1
    • Remove the chain brake cover.
  6. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Remove the tensioner assembly: 步骤 6 中的图像 1,1
    • Twist the tension screw clockwise until the slide bar stops at the right end.
    • Remove the single 15.7 mm long T27 screw holding the chain tensioner assembly in place.
  7. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 7 中的图像 1,1
    • Use your fingers to pull the assembly out of its recess and remove it.
  8. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 8 中的图像 1,1
    • If the packing ring did not come out with the assembly, remove it from the recess.
  9. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement, Assemble the replacement tensioner: 步骤 9 中的图像 1,1
    • The next three steps show how to prepare the new tensioning assembly for replacement.
    • Lightly lubricate the packing ring and press it into the back of the adjustment screw.
  10. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 10 中的图像 1,1
    • Slide the adjustment screw into the tensioning assembly such that the gears mesh together.
  11. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 11 中的图像 1,1
    • Slide the shaped plastic bearing onto the end of the assembly.
    • Lightly lubricate all moving surfaces.
  12. Makita Chain Saw EA6100PR 2017 Chain Tensioner and Slide Replacement: 步骤 12 中的图像 1,1
    • Line up the tensioning assembly with its recess in the chainsaw and push it into the recess.
    • Make sure that the black plastic bearing slides in rounded-edge first.
结论
5等其他人完成本指南。
Arthur Shi
于01/03/18注册
252,792 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 27
总计 2,333
