跳转到主内容
加入维修社区 - 创建账户
Magic Bullet NutriBullet Power Cord Replacement
你所需要的
    1. Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,2 Magic Bullet NutriBullet Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,2
      • Before beginning, make sure the device is unplugged.
      • With a Phillips head #2 screwdriver, begin unscrewing the four 10mm screws located on the bottom of the power base.
      添加评论
    2. Magic Bullet NutriBullet Power Cord Replacement: 步骤 2 中的图像 1,1
      • Once the screws are removed, pull the plastic base up gently.
      • Once the plastic base is removed, there is a fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      添加评论
    3. Magic Bullet NutriBullet Power Cord Replacement: 步骤 3 中的图像 1,1
      • Gently lift the power cord from its side slot and place it to the side.
      添加评论
    4. Magic Bullet NutriBullet Power Cord Replacement: 步骤 4 中的图像 1,2 Magic Bullet NutriBullet Power Cord Replacement: 步骤 4 中的图像 2,2
      • With the Phillips head #2 screwdriver, remove the two 10mm screws that secure the white bracket.
      • The white safety bracket holds the cord down. After removing it, the cord will be free.
      添加评论
    5. Magic Bullet NutriBullet Power Cord Replacement: 步骤 5 中的图像 1,1
      • After removing the gray base and silver casing, the wires will now be free and you will have easy access to them.
      • Gently pull out the two plastic covers at the end of the wires.
      添加评论
    6. Magic Bullet NutriBullet Power Cord Replacement: 步骤 6 中的图像 1,1
      • Use tape or clamps to hold the wires together for an easy soldering experience.
      • Using a soldering iron, solder your new wire to the red wire.
      添加评论
结论
Since this guide replacement requires cutting wires, if you want to reassemble this device, you must first re-solder new wires before following the steps backwards to reassemble the device.
取消:我没有完成这个指南。
3等其他人完成本指南。
Geary Yu
于01/22/15注册
1,277 声望
创作了3篇指南
团队
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G8
4 名成员
创作了19篇指南
7指南评论
where am I going to be the magic bullet repair
Or
there a service center here in the philippines?
Thank u.
florentinokarenjoy24 - 回复 分享
Is there a service centre in Singapore?
I just bought the gadget in Melbourne (from Harvey Norman Nunawarding) last week. We used it yesterday but after one round of spinning, gadget went dead.
What could go round and to fix it at home?
Michael Lee - 回复 分享
Can I plug the Magic Bullet in 220v?
Sovelita Tenerife - 回复 分享
Where can I get a replacement cable from?
victoria hatton - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 100
总计 17,517
