跳转到主内容
加入维修社区 - 创建账户
Magic Bullet NutriBullet Outside Casing Replacement
你所需要的
    1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: 步骤 1 中的图像 1,1
      • Unplug the device from the wall and turn the powerbase upside down.
      询问修复机器人
      添加评论
    2. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 2 中的图像 1,2 Magic Bullet NutriBullet Outside Casing Replacement: 步骤 2 中的图像 2,2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      询问修复机器人
      添加评论
    3. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 3 中的图像 1,1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      询问修复机器人
      添加评论
    4. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 4 中的图像 1,1
      • Lift the power cord to remove it from the side slot on the curved base.
      添加评论
    5. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 5 中的图像 1,2 Magic Bullet NutriBullet Outside Casing Replacement: 步骤 5 中的图像 2,2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      添加评论
    6. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 6 中的图像 1,1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      询问修复机器人
      添加评论
    7. Magic Bullet NutriBullet Outside Casing Replacement: 步骤 7 中的图像 1,1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      询问修复机器人
      添加评论
    1. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: 步骤 8 中的图像 1,1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
Angela Wong
于01/22/15注册
1,177 声望
创作了3篇指南
团队
Cal Poly, Team 19-8, Maness Winter 2015 Cal Poly, Team 19-8, Maness Winter 2015 的会员
CPSU-MANESS-W15S19G8
4 名成员
创作了19篇指南
4指南评论
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - 回复 分享
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - 回复 分享
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - 回复 分享
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 76
总计 8,800
