跳转到主内容
加入维修社区 - 创建账户
Magic Bullet MB1001B Activator Replacement
你所需要的
    1. Magic Bullet MB1001B Activator Replacement, Base Gear: 步骤 1 中的图像 1,3 Magic Bullet MB1001B Activator Replacement, Base Gear: 步骤 1 中的图像 2,3 Magic Bullet MB1001B Activator Replacement, Base Gear: 步骤 1 中的图像 3,3
      • Use pliers to grip the gear inside of the top of the device.
      • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
      • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
      • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
      添加评论
    1. Magic Bullet MB1001B Activator Replacement, Casing: 步骤 2 中的图像 1,1
      • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
      询问修复机器人
      添加评论
    2. Magic Bullet MB1001B Activator Replacement: 步骤 3 中的图像 1,1
      • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    3. Magic Bullet MB1001B Activator Replacement: 步骤 4 中的图像 1,1
      • Remove the black base plate.
      询问修复机器人
      添加评论
    4. Magic Bullet MB1001B Activator Replacement: 步骤 5 中的图像 1,1
      • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    5. Magic Bullet MB1001B Activator Replacement: 步骤 6 中的图像 1,1
      • Remove the white plastic cable guide.
      询问修复机器人
      添加评论
    6. Magic Bullet MB1001B Activator Replacement: 步骤 7 中的图像 1,1
      • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
      询问修复机器人
      添加评论
    7. Magic Bullet MB1001B Activator Replacement: 步骤 8 中的图像 1,1
      • Remove the black base.
      询问修复机器人
      添加评论
    8. Magic Bullet MB1001B Activator Replacement: 步骤 9 中的图像 1,1
      • Remove the three white rubber spacers with the spudger.
      添加评论
    9. Magic Bullet MB1001B Activator Replacement: 步骤 10 中的图像 1,1
      • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
      添加评论
    10. Magic Bullet MB1001B Activator Replacement: 步骤 11 中的图像 1,1
      • Remove the motor.
      询问修复机器人
      添加评论
    1. Magic Bullet MB1001B Activator Replacement, Activator: 步骤 12 中的图像 1,2 Magic Bullet MB1001B Activator Replacement, Activator: 步骤 12 中的图像 2,2
      • Wedge a flathead screwdriver in between the casing and white plastic activator.
      • Pry the white plastic activators from the casing as needed.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 12-13, Maness Fall 2015 Cal Poly, Team 12-13, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G13
4 名成员
创作了13篇指南
4指南评论
You gotta be kidding me?
marcomolinero72 - 回复 分享
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - 回复 分享
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - 回复 分享
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 57
总计 10,094
