跳转到主内容
加入维修社区 - 创建账户
MageGee Key Caps Replacement
你所需要的
    1. MageGee Key Caps Replacement, Key Caps: 步骤 1 中的图像 1,1
      • Test out which keys are the ones that are sticking and giving you trouble.
      • If you have a lot of keys that stick you might want to take note of which ones they or, or alternatively replace your entire keyboard's key caps.
      询问修复机器人
      添加评论
    2. MageGee Key Caps Replacement: 步骤 2 中的图像 1,2 MageGee Key Caps Replacement: 步骤 2 中的图像 2,2
      • Remove the damaged keys with a key cap remover by gently pressing onto the desired key cap. Pull gently and the key cap will come off.
      • Make a note of where the keys are located so you know where to replace them.
      询问修复机器人
      添加评论
    3. MageGee Key Caps Replacement: 步骤 3 中的图像 1,1
      • When removing the keys, remember where each one goes. You can place it in the order it was taken out to help you keep track.
      询问修复机器人
      添加评论
    4. MageGee Key Caps Replacement: 步骤 4 中的图像 1,2 MageGee Key Caps Replacement: 步骤 4 中的图像 2,2
      在这个步骤中使用的工具:
      • Check the keyboard for any blockages or obstructions and remove them with tweezers.
      • Alternatively: use your fingers or any other grabbing tools like a pair of small tongs.
      询问修复机器人
      添加评论
    5. MageGee Key Caps Replacement: 步骤 5 中的图像 1,1
      • Clean the area with a cloth or antibacterial wipe to remove any debris you might have missed.
      • Remember, water damages electronics so be very careful with this step.
      询问修复机器人
      添加评论
    6. MageGee Key Caps Replacement: 步骤 6 中的图像 1,1
      • Check your removed key caps to see if they are still functional, if not, you may want to get additional key caps to replace the old ones.
      询问修复机器人
      添加评论
    7. MageGee Key Caps Replacement: 步骤 7 中的图像 1,1
      • If your key caps were damaged, take out corresponding new key caps to replace the old damaged ones.
      询问修复机器人
      添加评论
    8. MageGee Key Caps Replacement: 步骤 8 中的图像 1,3 MageGee Key Caps Replacement: 步骤 8 中的图像 2,3 MageGee Key Caps Replacement: 步骤 8 中的图像 3,3
      • Insert the new key caps in by lining it up with the other keys and pressing it gently into the correct place.
      询问修复机器人
      添加评论
    9. MageGee Key Caps Replacement: 步骤 9 中的图像 1,1
      • Test out your new key caps and double check its functionality.
      询问修复机器人
      添加评论
    10. MageGee Key Caps Replacement: 步骤 10 中的图像 1,2 MageGee Key Caps Replacement: 步骤 10 中的图像 2,2
      • Plug in your keyboard and there you have it, a functional mechanical keyboard.
      • If your keyboard is not fixed, it may be a circuit issue which will result in needing your whole keyboard needing to be replaced.
      询问修复机器人
      添加评论
结论
Now your keys on your mechanical keyboard should be working as good as new.
取消:我没有完成这个指南。
Lisa Nguyen
于06/29/21注册
181 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 93
总计 6,100
