简介
Use guide to replace a worn or broken track ball assembly.
你所需要的
Orient the computer so the battery is facing you.
Slide the gray plastic battery cover to the right.
Orient the computer right side up with the rear facing you.
Open the Input/Output (I/O) door.
Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
Lift the lower case to remove it.
Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
另外一个人完成了本指南。
