跳转到主内容
Macbook Pro 14" 2023 Trackpad Replacement
你所需要的
  1. Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the lower case: 步骤 1 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the lower case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    购买
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Macbook Pro 14" 2023 Trackpad Replacement, Unclip the lower case: 步骤 2 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Unclip the lower case: 步骤 2 中的图像 2,2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. Macbook Pro 14" 2023 Trackpad Replacement, Release the right clips: 步骤 3 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the right clips: 步骤 3 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the right clips: 步骤 3 中的图像 3,3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. Macbook Pro 14" 2023 Trackpad Replacement, Release the left clips: 步骤 4 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the left clips: 步骤 4 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the left clips: 步骤 4 中的图像 3,3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. Macbook Pro 14" 2023 Trackpad Replacement, Release the sliding clips: 步骤 5 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the sliding clips: 步骤 5 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Release the sliding clips: 步骤 5 中的图像 3,3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. Macbook Pro 14" 2023 Trackpad Replacement, Remove the lower case: 步骤 6 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Remove the lower case: 步骤 6 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Remove the lower case: 步骤 6 中的图像 3,3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery board: 步骤 7 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery board: 步骤 7 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery board: 步骤 7 中的图像 3,3
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. Macbook Pro 14" 2023 Trackpad Replacement: 步骤 8 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement: 步骤 8 中的图像 2,2
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. Macbook Pro 14" 2023 Trackpad Replacement: 步骤 9 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement: 步骤 9 中的图像 2,2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the trackpad cable bracket: 步骤 10 中的图像 1,1
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
  11. Macbook Pro 14" 2023 Trackpad Replacement, Remove the trackpad cable bracket: 步骤 11 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Remove the trackpad cable bracket: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the trackpad cable: 步骤 12 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the trackpad cable: 步骤 12 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. Macbook Pro 14" 2023 Trackpad Replacement, Reposition the trackpad cable: 步骤 13 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Reposition the trackpad cable: 步骤 13 中的图像 2,2
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery board: 步骤 14 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery board: 步骤 14 中的图像 2,2
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. Macbook Pro 14" 2023 Trackpad Replacement: 步骤 15 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement: 步骤 15 中的图像 2,2
  16. Macbook Pro 14" 2023 Trackpad Replacement: 步骤 16 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement: 步骤 16 中的图像 2,2
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. Macbook Pro 14" 2023 Trackpad Replacement, Remove the data cable: 步骤 17 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Remove the data cable: 步骤 17 中的图像 2,2
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the battery connector: 步骤 18 中的图像 1,1
    • Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
  19. Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery connector: 步骤 19 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery connector: 步骤 19 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Disconnect the battery connector: 步骤 19 中的图像 3,3
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the trackpad: 步骤 20 中的图像 1,2 Macbook Pro 14" 2023 Trackpad Replacement, Unfasten the trackpad: 步骤 20 中的图像 2,2
    • Use a T5 Torx driver to remove the ten 5.7 mm screws securing the trackpad:
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  21. Macbook Pro 14" 2023 Trackpad Replacement, Remove the trackpad: 步骤 21 中的图像 1,3 Macbook Pro 14" 2023 Trackpad Replacement, Remove the trackpad: 步骤 21 中的图像 2,3 Macbook Pro 14" 2023 Trackpad Replacement, Remove the trackpad: 步骤 21 中的图像 3,3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad should separate and lay flat on the display.
    • As you remove the trackpad, be very careful not to lose the six small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Carefully feed the trackpad's ribbon cable through its slot in the frame.
  22. Macbook Pro 14" 2023 Trackpad Replacement: 步骤 22 中的图像 1,1
    • Remove the trackpad.
    • During reassembly:
    • Make sure your new trackpad has a ribbon cable installed. If necessary, transfer the old cable, or install the one your new trackpad came with.
    • Make sure that each of the six washers are present before you install the trackpad.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2023 Answers community for help.
另外一个人完成了本指南。
Chayton Ritter
于08/21/20注册
18,618 声望
创作了102篇指南
团队
Guide Team Guide Team 的会员
Staff
6 名成员
创作了7,844篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 45
总计 817
