跳转到主内容
加入维修社区 - 创建账户
MacBook Unibody Model A1278 RAM Replacement
你所需要的
    1. MacBook Unibody Model A1278 RAM Replacement, Access Door: 步骤 1 中的图像 1,1
      • With the case closed, place the Unibody top-side down on a flat surface.
      • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
      添加评论
    2. MacBook Unibody Model A1278 RAM Replacement: 步骤 2 中的图像 1,1
      • The access door should now be raised enough to lift it up and out of the Unibody.
      询问修复机器人
      添加评论
    1. MacBook Unibody Model A1278 RAM Replacement, Battery: 步骤 3 中的图像 1,1
      • Be sure the access door release latch is vertical before proceeding.
      • Grab the white plastic tab and pull the battery up and out of the Unibody.
      添加评论
    1. MacBook Unibody Model A1278 RAM Replacement, Lower Case: 步骤 4 中的图像 1,1
      • Remove the following eight screws securing the lower case to the chassis:
      • One 3 mm Phillips screw.
      • Four 3.5 mm Phillips screws.
      添加评论
    2. MacBook Unibody Model A1278 RAM Replacement: 步骤 5 中的图像 1,1
      • Using both hands, lift and remove the lower case off the upper case.
      添加评论
    1. MacBook Unibody Model A1278 RAM Replacement, RAM: 步骤 6 中的图像 1,1
      • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
      • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      询问修复机器人
      添加评论
    2. MacBook Unibody Model A1278 RAM Replacement: 步骤 7 中的图像 1,1
      • After the RAM chip has popped up, pull it straight out of its socket.
      • Repeat this process if a second RAM chip is installed.
      添加评论
结论
取消:我没有完成这个指南。
296等其他人完成本指南。
21指南评论
Open back of unit, press two grey sides surrounding the chip, pull out the top (leave the bottom 2gb in) put in the new (4gb) chip; now there are 6gb of ram.
mrstiffanyjudson - 回复 分享
I just upgraded to 2 4GB chips. Works fine sofar!
Sten Folkerman - 回复 分享
That's awesome! I thought that I could only upgrade the RAM to 4GB (which is what I have now). Can you give me the type of RAM that you installed? I have this exact model MacBook.
Jonathan - 回复 分享
Uh oh. I replaced my 2 1GB ram with 2 2GB. I turned it on and it beeps at me about every second, the front status light blinks in time, but nothing else....what next?
dunkelcreature - 回复 分享
Sounds like bad RAM. I would contact who you purchased it from. If it was us, email support [at] ifixit [dot] com
Scott Dingle - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 31
过去 30 天: 138
总计 194,012
