跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 17" Unibody RAM Replacement
你所需要的
  1. MacBook Pro 17" Unibody RAM Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Seven 3 mm Phillips screws.
    添加评论
  2. MacBook Pro 17" Unibody RAM Replacement: 步骤 2 中的图像 1,2 MacBook Pro 17" Unibody RAM Replacement: 步骤 2 中的图像 2,2
    • Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
    • During reassembly, carefully align the lower case and then press it firmly until both clips engage.
    • Remove the lower case.
    添加评论
  3. MacBook Pro 17" Unibody RAM Replacement, Battery: 步骤 3 中的图像 1,3 MacBook Pro 17" Unibody RAM Replacement, Battery: 步骤 3 中的图像 2,3 MacBook Pro 17" Unibody RAM Replacement, Battery: 步骤 3 中的图像 3,3
    • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
    • If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
    • If the plastic tab is missing, use a spudger to pry the connector up from its socket.
    • Pull the tab parallel to the face of the logic board.
    添加评论
  4. MacBook Pro 17" Unibody RAM Replacement, RAM: 步骤 4 中的图像 1,3 MacBook Pro 17" Unibody RAM Replacement, RAM: 步骤 4 中的图像 2,3 MacBook Pro 17" Unibody RAM Replacement, RAM: 步骤 4 中的图像 3,3
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
    添加评论
结论
取消:我没有完成这个指南。
133等其他人完成本指南。
9指南评论
Thank you iFixIt. Your tutorial gave me confidence to move forward and get inside my computer. I agree with bhodges2, a great opportunity to clean. I'd keep a can of compressed air handy next time. I would also use a separate compartment for each screw. I treated the case like a wheel, lightly tightening each first. Still, the 3mm screws do not seem not entirely interchangeable. Mixing them around, not forcing anything, eventually worked out.
paleo5 - 回复 分享
These instructions worked perfectly, thank you!
Ruth H - 回复 分享
Folded masking tape to make two sided.Made rectangle like shape of Mac.Put the screws on the tape in order, so I would not mix screws or loose them.That process took longer than installation. Done in 10 mins..No need to remove battery.Put finger on metal stated by Apple.Now going to add 16gigs more in my IMac.Thanks for the illustrations Andrew !!!!
Gary howarth - 回复 分享
Hi may i know what is the maximum size of GB for RAM that model A1297 MBP 17" Early 2009 can support? can it support 16GB. TIA.
rewtz - 回复 分享
Late 2011 Macbook Pro 17" A1297 2.5GHz i7-2860QM supports 1600MHz DDR3 RAM according to Intel's Ark (http://ark.intel.com/products/53476/Inte...), faster than what Apple suggests. I tried 2x8GB 1600MHz SODIMMs (opposite 2x16GB maximum as supported by Intel, yet cannot find the modules anywhere) and it works. The machine is a lot faster compared to the default 1333MHz RAM.
Mel - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 106
总计 100,464
