跳转到主内容
MacBook Pro 15" Unibody Late 2011 Feet Replacement
你所需要的
  1. MacBook Pro 15" Unibody Late 2011 Feet Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 2 中的图像 1,1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 步骤 3 中的图像 1,3 MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 步骤 3 中的图像 2,3 MacBook Pro 15" Unibody Late 2011 Feet Replacement, Feet: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 4 中的图像 1,1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 5 中的图像 1,1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 6 中的图像 1,1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 7 中的图像 1,3 MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 7 中的图像 2,3 MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 7 中的图像 3,3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 15" Unibody Late 2011 Feet Replacement: 步骤 8 中的图像 1,1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
结论
10等其他人完成本指南。
Arthur Shi
于01/03/18注册
258,874 声望
创作了531篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,058篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,580
