当前版本的文档还未经巡查,您可以查看最新的已查核版本。
三个五角螺丝将电池固定在上壳上。可以使用此螺丝刀拆除它们。
如果你没有五角螺丝刀,可以在夹点中使用 1.5 mm 平头螺丝刀。在尝试打开螺钉之前,确保平头螺丝刀的头部紧贴螺钉头的五个“点”中的两个,因为松配合将很容易剥离螺钉头。
如果你的螺丝刀头不合适,找一个更大的头并将其归档,直到它完全适合再继续进行。
你不必按照步骤 3 - 7 卸下电池以更换硬盘驱动器。但是,建议在进行操作之前从电子设备中取出所有电源。
通过塑料拉条提起电池,将其从上壳的长边滑出。
不要试图完全取出电池。
Remove two Phillips screws securing the hard drive bracket to the upper case.
These screws are captive to the hard drive bracket.
Lift the the retaining bracket out of the upper case.
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
Two 1.5 mm Phillips screws.
Two 4 mm Phillips screws.
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
Gently pull the sensor bracket cable out of the ZIF connector.
Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
