简介
使用本指南,借助 iFixit 提供的带有粘合剂去除剂的工具包,安全地拆除 MacBook Pro 中粘合的电池。粘合剂去除剂旨在弱化固定电池的胶水,让您能轻松将其取出。
iFixit 粘合剂去除剂易燃。 请在通风良好的区域执行此操作。请勿吸烟或在明火附近作业。
为将损坏风险降至最低,请在此操作开始前打开 MacBook 并让电池充分放电。 如果意外刺穿,充满电的锂离子电池可能引发危险且无法控制的火灾。 如果您的电池看起来鼓包或肿胀,请采取额外的预防措施。
注意:用于溶解电池粘合剂的溶剂可能损坏某些塑料。请遵循所有说明,并在涂抹粘合剂去除剂时小心谨慎。
你所需要的
开机,并打开终端。
将以下命令复制粘贴到(或完全键入)终端窗口中:
sudo nvram AutoBoot=%00
按[回车]。如果出现钥匙提示,请输入管理员密码(开机密码)并再次按[回车]。注意:您的回车键也可能标有「⏎」或 return。
sudo nvram AutoBoot=%03
120等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
75指南评论
This is an awesome guide. My girlfriend’s MacBook Pro was diagnosed with a logic board failure by the repair centre. The repair cost was going to be more than a new 6-core Mac Mini.
I tinkered with the device, and thanks to the help of the iFixit community, a battery fault was diagnosed. Installed a new battery and the problem was solved!
Everything went perfectly. Thanks for the great guide :)
Hello I bougth the battery on this site my model is A1707, I followed the procedure and when I turned it on it stays in 1% and says condition: Replace now… what can I do?
Hi Rafael, make sure you’ve calibrated your battery first. If that doesn’t fix anything and you’re using an iFixit battery, contact our customer support team and they’ll help you out. Otherwise you can post your question on the Answers Forum—there are a bunch of experts there that can offer advice.
Adam O'Camb - 回复 分享
My late 2016 model MBP’s battery had swollen after 3 years (2 months out of warranty). Apple wanted $850 to send it in and replace it. I purchased a new battery and it’s kit for a fourth of the price from iFixit. 2.5 hours later, and everything seems to be working smoothly. The guide was spot on.
amandalasha - 回复 分享
