跳转到主内容
MacBook Pro 15" Retina Display Early 2013 SSD Replacement
你所需要的
  1. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 步骤 2 中的图像 1,1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, Battery Connector: 步骤 3 中的图像 1,1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 步骤 4 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 步骤 4 中的图像 2,2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Early 2013 SSD Replacement, SSD: 步骤 5 中的图像 1,1
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  6. MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 步骤 6 中的图像 1,2 MacBook Pro 15" Retina Display Early 2013 SSD Replacement: 步骤 6 中的图像 2,2
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
结论
60等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,023 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,755篇指南
17指南评论
Where is the left fan in the pic? Please tell me I don't need to remove the fan before doing the replacement.
Ethan - 回复
I see that for all the guides for all the MBP models with solid state storage, the battery is disconnected before the solid state storage is removed. Why?
Traditional hard drives and SSDs don't have to have their batteries disconnected before removing...do they?
Hobowan Kenobi - 回复
You should remove it. It's just good practice when doing anything internal on any laptop.
farleyaustin -
这个ssd的接口是什么呢?我应该购买什么型号的ssd能适配这个,怎么筛选?
lizhao - 回复
Can I update my SSD to 1TB from 512GB? RMBP 2013 Early
FAN Guoxing - 回复
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 104
过去 30 天: 582
总计 107,281
