你所需要的
使用撬棒扁平的一端,从逻辑板上撬起低音音箱和右扬声器插头。
The first time i tried this on a MBP 13 I broke the connector form the board. It should be noted that you have to be very careful in this step, as the plug fits very tightly and you can easily use too much force to tear the connector from the board. Use a second spudger to hold down the connector at its border and try very gently using a second spudger to move the plug out of the connector upwards.
向光驱方向拉动摄像头线缆插头,来将其与逻辑板断开。
As mentioned, the socket can be easily damaged when re-inserting it. I didn't care enough and one pin was damaged. Wifi was not detected.
Hopefully the pin was not broken (only bent). Putting it back in its correct position, the wifi re-appeared.
使用你的指甲或者撬棒尖端来解锁键盘线缆插座上的ZIF连接器滑杆。
使用撬棒将键盘线缆从插座中滑出。
Sometimes spulger is not the best tool to slide the cable out. If it is difficult to slide, try two toothpicks to pull the cable from two sides simultaneosly.
Toothpicks did the trick, thanks
As Mateo said, replacing the zif cable is NOT easy, and in this case, will leave you with a computer that won't power on- this cable connects the power button. I learned a trick somewhere for dealing with these cables- put a piece of good sticky tape on the cable, and use it to pull it back into the connector. Works every time.
Yeah! The tape trick worked for me. Thanks!
Thank you Steve, it’s works perfectly.
撕下键盘背光排线插座上的小黑色胶带。
Be very careful while taking this black tape off. I accidentally broke the chip off the motherboard and so my keyboard is not backlit any more.
Asim Akath - 回复
使用撬棒尖端来解锁键盘背光线缆ZIF插座上的小滑杆。
使用 撬棒来将键盘背光排线线缆从插座中滑出。
Be especially careful as my hole socket detached from the board. It would have helped to vertically press the socket to the board with the tip of a spudger. Thus partially blocking the strap, you can first peel the free end, then change position and peel the rest. Slide the ribbon cable perfectly horizontally.
I had the same issue of trying to get the ZIF cable back in but found that if I used a piece of scotch tape, it worked. I followed this guide. MacBook unibody keyboard ribbon cable won't go in
A reassembly trick that works for me is to use some 3/4" blue painters tape to stick to the very back (lower end) of the ribbon cable so I can pull it up and back before locking the cam. Trying to get a good grip without cutting, or crimping the ribbon means no tweezers or pliers can be used.
使用撬棒扁平一端从逻辑板撬起电量显示线缆插头。
If you’re swapping top cases, you might need to remove the battery indicator from the case and swap it to the replacement top case. It attaches with three very tiny Phillips screws. I wasn’t aware that my replacement top case didn’t have this part and got confused when reversing the steps to reassemble and I didn’t have this connector. I had to take the battery back out in order to swap the indicator over.
使用撬棒尖端来将麦克风从将其固定到顶壳的胶带中撬出。
on the Australian/Asia version speaker cable is located underneath the logic board.
将逻辑板从其左边缘提起,并抬起它,直到端口完全从顶壳中移出。
将逻辑板从顶壳的侧面拉出,将其拆下来,请小心交流电源板可能被卡住。
Be careful while taking the board out, as the heatsink usually is caught by the optic drive.
mid 2012: Careful of the left speaker (on your right because unit is upside down). Gently remove with spudger tool before removing logic board and when reinstalling press firmly back into place with spudger. Install speaker after putting logic board in place but before installing screws.
JASON CULP - 回复
要重新组装您的设备,请按照本指南的相反顺序进行操作。
2等其他人完成本指南。
由衷感谢以下译者:
93%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
On my system the pad on top of the connector was shifted making the bracket difficult to rotate into the up position. The bracket looks like a handle so my first instinct was to pull it straight up. Big mistake. I ended up popping the brass guard off the connector on the logic board. The instructions could benefit from an arrow indicating the direction to pull and rotation of the bracket.
highnoontoday - 回复
