跳转到主内容
加入维修社区 - 创建账户
此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
MacBook Core Duo 内存更换
你所需要的
    1. MacBook Core Duo 内存更换, 电池: 步骤 1 中的图像 1,1
      • 使用硬币或撬棒将电池锁定螺丝顺时针旋转 90 度。
      添加评论
    2. MacBook Core Duo 内存更换: 步骤 2 中的图像 1,1
      • 将电池从电脑中取出。
      询问修复机器人
      添加评论
    1. MacBook Core Duo 内存更换, 内存盖板: 步骤 3 中的图像 1,1
      • 从电池仓后壁沿线拆下三颗等距分布的十字螺丝。
      • 这些螺丝是与金属内存盖板一体的防脱螺丝。
      • 安装内存盖板时,请使用撬棒将泡沫衬垫重新塞入后壁后方,以确保电池有适当的间隙。
      添加评论
    2. MacBook Core Duo 内存更换: 步骤 4 中的图像 1,1
      • 提起 L 形内存盖板,将其向右滑动,然后从电脑中取出。
      添加评论
    1. MacBook Core Duo 内存更换, 内存: 步骤 5 中的图像 1,1
      • 动作要快但要小心,拨动拨杆向左,将 RAM 芯片从隔间中滑出。
      • 与 iBook 系列不同,MacBook 有两个 RAM 插槽,支持最高 2 GB 的内存。
      添加评论
结论
要重新组装设备,请按相反顺序执行这些说明。
取消:我没有完成这个指南。
128等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了632篇指南
5指南评论
I followed these direction to upgrade my ram from 2 512MB chips to 2 1GB chips. They were simple, but I hit a snag somewhere because when I went to turn back on my computer the light on the slide just blinked several times and no start up ocurred. How do you know that the new RAM chips are in sufficiently? Do you have to press them in until they click or lock? Mine just slid in and are somewhat "loose" still.
thanks!
Madeleine - 回复 分享
Madeline I have the same question about re inserting the ram but can't find an answer
did you?
Hank
hlsilvia@flhi.org
hank1930 - 回复 分享
I have followed the steps and the computer kept crashing when i started it with the RAM. Once i put the old pne back in, it started as smootly as before: i think these RAMs are not compatible with the A1181 model.
chnafou - 回复 分享
I don't know why some people are mentioning a torx. This is a regular phillips. Had one laying around from my old-style mac mini upgrade. It couldn't be easier. It's almost like the new style mac mini ram upgrade. So effortless.
Maximillian Charles - 回复 分享
Please note. The ram modules have to be pushed all the way in until they click in place. You have to push them quite hard to do this. If the ram modules just slide in until they stop then they won’t make contact.
Patch - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 133
总计 126,612
