跳转到主内容
加入维修社区 - 创建账户
MacBook Core Duo MagSafe Board Replacement
你所需要的
    1. MacBook Core Duo MagSafe Board Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      添加评论
    2. MacBook Core Duo MagSafe Board Replacement: 步骤 2 中的图像 1,1
      • Lift the battery out of the computer.
      询问修复机器人
      添加评论
    1. MacBook Core Duo MagSafe Board Replacement, Memory Cover: 步骤 3 中的图像 1,1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      添加评论
    2. MacBook Core Duo MagSafe Board Replacement: 步骤 4 中的图像 1,1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      添加评论
    1. MacBook Core Duo MagSafe Board Replacement, Upper Case: 步骤 5 中的图像 1,1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      添加评论
    2. MacBook Core Duo MagSafe Board Replacement: 步骤 6 中的图像 1,1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      添加评论
    3. MacBook Core Duo MagSafe Board Replacement: 步骤 7 中的图像 1,1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      添加评论
    4. MacBook Core Duo MagSafe Board Replacement: 步骤 8 中的图像 1,1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      添加评论
    5. MacBook Core Duo MagSafe Board Replacement: 步骤 9 中的图像 1,1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      添加评论
    6. MacBook Core Duo MagSafe Board Replacement: 步骤 10 中的图像 1,1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      添加评论
    7. MacBook Core Duo MagSafe Board Replacement: 步骤 11 中的图像 1,1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      添加评论
    8. MacBook Core Duo MagSafe Board Replacement: 步骤 12 中的图像 1,1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      添加评论
    1. MacBook Core Duo MagSafe Board Replacement, MagSafe Board: 步骤 13 中的图像 1,1
      • Remove the single Phillips screw securing the MagSafe board to the lower case.
      询问修复机器人
      添加评论
    2. MacBook Core Duo MagSafe Board Replacement: 步骤 14 中的图像 1,1
      • Use a spudger to rotate the MagSafe board up and out of its housing. It may be helpful to pull the lower case out slightly to provide additional clearance.
      询问修复机器人
      添加评论
    3. MacBook Core Duo MagSafe Board Replacement: 步骤 15 中的图像 1,1
      • Disconnect the MagSafe board from the logic board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
109等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了635篇指南
5指南评论
I did this and battery is charging but now MacBook doesn't boot up any ideas? I took it appart again and everything is connected ;(
miguelmeza - 回复 分享
broke the keyboard cable to motherboard BE CAREFUL!!!! ALL WORKING GOOD!
miguelmeza - 回复 分享
Does not boot up and did not break or damage the cable to motherboard. Any suggestions? The cable looks as new. But keeps booting for many minutes with spinning wheel
Andrej Spilevoj - 回复 分享
Before you do this - might be worth checking to see that the insulating gasket in the magsafe port is intact. I was about to buy a new board when I noticed that the gasket was broken (I wouldn’t have noticed there was even a gasket unless it was broken).
Turned out for me it was just this insulating gasket in the outside of the port that was stopping it charging and I didn’t even need to open the back. When I found part of it still intact, I guessed partial insulation might be that causing a short. The gasket is made of very thin tape and sure enough when I made a copy and put that in, it charged fine on the new charger I had bought. The old charger is dead (on this and a friend's machine) so I presume it was fried shorting while I repeatedly tried to charge before. P.S. I made the copy by making an inverse template by pressing Blutac into the port and used that as a block to print an outline onto the tape.
Sally-ann - 回复 分享
“Turned out for me it was just this insulating gasket in the outside of the port that was stopping it charging and I didn’t even need to open the back. When I found part of it still intact, I guessed partial insulation might be that causing a short. The gasket is made of very thin tape and sure enough when I made a copy and put that in, it charged fine on the new charger I had bought.”
INDEED!!! That was the same case for my macbook! the plastic film on the charger port was partly broken. I took off the rest of that broken film with a pin, then I cut out duct tape to fit and place around the pin connections, and that did the trick!!
Sol - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 101
总计 89,801
