跳转到主内容
加入维修社区 - 创建账户
MacBook Core Duo AirPort Card Replacement
你所需要的
视频概述
    1. MacBook Core Duo AirPort Card Replacement, Battery: 步骤 1 中的图像 1,1
      • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
      添加评论
    2. MacBook Core Duo AirPort Card Replacement: 步骤 2 中的图像 1,1
      • Lift the battery out of the computer.
      询问修复机器人
      添加评论
    1. MacBook Core Duo AirPort Card Replacement, Memory Cover: 步骤 3 中的图像 1,1
      • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
      • The screws are captive to the metal memory cover.
      • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
      添加评论
    2. MacBook Core Duo AirPort Card Replacement: 步骤 4 中的图像 1,1
      • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
      添加评论
    1. MacBook Core Duo AirPort Card Replacement, Upper Case: 步骤 5 中的图像 1,1
      • Remove the following 3 screws:
      • One 11 mm Phillips #00 in the middle of the case.
      • Two 14.5 mm Phillips #00.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      • The shorter of the three screws goes in the middle.
      添加评论
    2. MacBook Core Duo AirPort Card Replacement: 步骤 6 中的图像 1,1
      • Remove the following 3 screws from the rear wall of the battery compartment:
      • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
      • One 4 mm Phillips #00 on the right side.
      • When reinstalling these screws, press gently on the lower case to line up the screw holes.
      • These screws easily strip, so be careful while taking these particular screws out.
      添加评论
    3. MacBook Core Duo AirPort Card Replacement: 步骤 7 中的图像 1,1
      • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
      添加评论
    4. MacBook Core Duo AirPort Card Replacement: 步骤 8 中的图像 1,1
      • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
      添加评论
    5. MacBook Core Duo AirPort Card Replacement: 步骤 9 中的图像 1,1
      • Remove the following 4 screws from the back of the computer:
      • Two 7 mm shouldered Phillips on the far sides.
      • Two 10.5 mm Phillips toward the center.
      • Do not over-tighten these; you can cause the case to distort.
      添加评论
    6. MacBook Core Duo AirPort Card Replacement: 步骤 10 中的图像 1,1
      • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
      • It is not necessary to remove the similar screws on the other side of the computer.
      添加评论
    7. MacBook Core Duo AirPort Card Replacement: 步骤 11 中的图像 1,1
      • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
      • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
      • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
      • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
      添加评论
    8. MacBook Core Duo AirPort Card Replacement: 步骤 12 中的图像 1,1
      • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
      • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
      • Do not pry from the bottom or the top, but from the sides.
      • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
      添加评论
    1. MacBook Core Duo AirPort Card Replacement, AirPort Card: 步骤 13 中的图像 1,1
      • Disconnect the two antenna cables from the Airport card on the left side of the computer.
      询问修复机器人
      添加评论
    2. MacBook Core Duo AirPort Card Replacement: 步骤 14 中的图像 1,1
      • Remove the following 2 screws from the Airport card:
      • One 3 mm Phillips from the left side.
      • One 8 mm Phillips from the right side.
      询问修复机器人
      添加评论
    3. MacBook Core Duo AirPort Card Replacement: 步骤 15 中的图像 1,1
      • Grasp the Airport card at its top and slide it toward the screen and out of the computer.
      添加评论
结论
取消:我没有完成这个指南。
112等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了635篇指南
5指南评论
You'll have to remove a lot of different sized screws. Be careful to take care of properly placing them while doing the steps - you'll have to put them back the way you took them out. I personally placed them the way the pictures show them.
Gyuri Ordody - 回复 分享
I did not install an AirPort card However I used the guide to open my MacBook to give it a good cleaning inside. Perfect!
deejai58 - 回复 分享
Thank you thank you thank you. A lifelong PC user, with their wife's MacBook ( so lots of pressure not to break it) was able to follow this walk through and make their wife so happy with the improved performance. Thanks for giving me the confidence to tackle other upgrades that can be done on this MacBook!
-Geoff K
Jeannine Guenette - 回复 分享
These instructions were really fantastic. SO easy to follow, and I'm especially glad that there was a video which reinforced the written instructions. Thank you!
christopher e m - 回复 分享
do you have any idea for the laptop vostro 1000 how?
ROBERT Dyrmishi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 32
过去 30 天: 112
总计 352,551
