此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
更换故障散热风扇非常简单,这能让你的笔记本电脑保持凉爽运行。
你所需要的
从电脑的光驱(右)侧拆下两颗十字螺丝:
两颗 5.2 mm 十字 #00 螺丝,带杆(杆直径 2.3 mm,长度 3.25 mm)(螺丝头:直径 3.2 mm,厚度 0.5 mm)
要重新组装设备,请按相反顺序执行这些说明。
309等其他人完成本指南。
23指南评论
My wife's MacBook has been overheating for some time, and then shutting itself down. Your instructions were great, but I did note that I needed to unscrew the cable tie near the speaker in Step 17.
The system had some dust in it, used the air can to spray it all out. Dust was on the heatsink vents, too. Closed it all up, and peak temps during a software install that crashed it three times yesterday was 145F - yesterday it was passing 170F and crashing.
Thanks for the instructions, ifixit!
Download and print out the PDF version of the repair guide. Tape the screws to their corresponding image in the guide so that you can't go wrong!
Good Idea. I generally sketch up rough diagrams and putsmall pieces of double sided tapes and stick the screws on my drawing.
Sandeep Giri - 回复 分享
