本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to replace a broken display.
你所需要的
视频概述
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
Pull the audio out ribbon cable off the adhesive securing it to the upper case.
Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Use the tip of a spudger to pull the fan cable connector straight away from its connector on the logic board.
Remove the two following screws securing the AirPort/Bluetooth board bracket to the upper case:
One 4.7 mm Phillips.
One 3.9 mm Phillips.
116等其他人完成本指南。
7条评论
Great guide. I was able to remove the components without any trouble. Be sure to label your screws, as there are so many.
Do you have a guide to put that macbook back togerher?
I was able to replace broken hinges without replacing the whole display. It takes patience and a bit of courage but it's doable (except if you are blonde and cute I guess ;)
Buenas tardes Alberto. Tengo necesidad de sustituir una bisagra de este modelo y no sé donde puedo adquirirla. Le agradecería que me dijera donde puedo comprarla. muchas gracias por adelantado
