跳转到主内容
加入维修社区 - 创建账户
MacBook Air 13" Mid 2011 Display Assembly Replacement
你所需要的
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Lower Case: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 2 中的图像 1,1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement, Battery Connector: 步骤 3 中的图像 2,2
      • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
      • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
      • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, I/O Board Cable: 步骤 4 中的图像 1,1
      • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 5 中的图像 1,1
      • Carefully peel the I/O board cable from the top of the fan.
      询问修复机器人
      添加评论
    3. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 6 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 6 中的图像 2,2
      • The following connector has an especially deep socket. Use care when disconnecting it.
      • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
      • Remove the I/O board cable.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Fan: 步骤 7 中的图像 1,1
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 8 中的图像 1,1
      • Peel the rubber gasket off the adhesive on the top of the fan.
      添加评论
    3. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 9 中的图像 1,1
      • Remove the following three screws securing the fan to the upper case:
      • One 3.6 mm T5 Torx screw
      • One 2.7 mm T5 Torx screw
      • One 3.6 mm T5 Torx screw with a short head
      添加评论
    4. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 10 中的图像 1,1
      • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, I/O Board: 步骤 11 中的图像 1,1
      • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
      询问修复机器人
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 12 中的图像 1,1
      • Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
      • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
      添加评论
    3. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 13 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 13 中的图像 2,2
      • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
      • Pry up from beneath the wires.
      • De-route the left speaker cable from its retainer on the I/O board.
      添加评论
    4. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 14 中的图像 1,1
      • Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
      添加评论
    5. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 15 中的图像 1,1
      • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
      添加评论
    6. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 16 中的图像 1,1
      • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Battery: 步骤 17 中的图像 1,1
      • Remove the following five screws securing the battery to the upper case:
      • Three 6.3 mm T5 Torx screws
      • Two 2.4 mm T5 Torx screws
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 18 中的图像 1,1
      • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      询问修复机器人
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Logic Board: 步骤 19 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement, Logic Board: 步骤 19 中的图像 2,2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 20 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 20 中的图像 2,2
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Use your spudger to help pull the cable out of its socket.
      询问修复机器人
      添加评论
    3. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 21 中的图像 1,1
      • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
      • Pry up from beneath the cables.
      添加评论
    4. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 22 中的图像 1,3 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 22 中的图像 2,3 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 22 中的图像 3,3
      • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
      • While holding the lock away from the socket, use the tip of a spudger and your fingers to gently remove the display data cable from its socket.
      • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
      添加评论
    5. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 23 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 23 中的图像 2,2
      • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
      添加评论
    6. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 24 中的图像 1,1
      • Gently de-route the antenna cables from the slot cut into the logic board.
      询问修复机器人
      添加评论
    7. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 25 中的图像 1,1
      • Remove the single 2.85 mm T5 Torx screw securing the SSD to the logic board.
      询问修复机器人
      添加评论
    8. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 26 中的图像 1,2 MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 26 中的图像 2,2
      • To avoid damaging its socket, do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      添加评论
    9. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 27 中的图像 1,1
      • Remove the six 6.3 mm T5 Torx screws securing the logic board to the upper case.
      添加评论
    10. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 28 中的图像 1,1
      • Remove the inner two 4.9 mm T8 Torx screws securing the antenna cable retainer and left clutch hinge to the upper case.
      添加评论
    11. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 29 中的图像 1,1
      • Push the antenna cable retainer away slightly and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
      添加评论
    12. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 30 中的图像 1,1
      • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
      • Hold the antenna cables out of the way as you lift the heat sink end of the logic board out of the upper case.
      添加评论
    1. MacBook Air 13" Mid 2011 Display Assembly Replacement, Display Assembly: 步骤 31 中的图像 1,1
      • Gently de-route the antenna cables out of the channel cut into the upper case.
      询问修复机器人
      添加评论
    2. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 32 中的图像 1,1
      • Remove the inner two 4.9 mm T8 Torx screws securing the right display hinge to the upper case.
      • We intentionally have you leave the third screw in to aid in future steps.
      添加评论
    3. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 33 中的图像 1,1
      • Open the display until it is perpendicular to the upper case and place it on a table as shown.
      • While holding the MacBook Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
      添加评论
    4. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 34 中的图像 1,1
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
      询问修复机器人
      添加评论
    5. MacBook Air 13" Mid 2011 Display Assembly Replacement: 步骤 35 中的图像 1,1
      • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
      • Once the two display hinges have cleared the upper case, remove the display and set it aside.
      添加评论
终点
取消:我没有完成这个指南。
103等其他人完成本指南。
附加文件
24指南评论
Sure would be nice if you could either add to the guide or have a new guide that continued the process and actually disassembled the screen assembly. It is no more difficult to take apart the display than it is to take apart an iPad.
jonlobb86 - 回复 分享
Thanks a ton for this guide! I got my MBAir back in working order in about an hour. The only weird thing I noticed was my MBAir battery unexpectedly registering at 0% upon re-seating. But it's charging so I suppose all's well that ends well.
jasontomczak - 回复 分享
This guide is way more than needed for the display replacement. Until it gets edited down, all you need to do is steps 1-3, 12, 22-24, 28, 31-35 from the "upper case replacement" guide (which is apparently what this guide is right now, instead of a display replacement guide as it is labeled).
brentp - 回复 分享
This is a really great comment! Thanks, you've saved me lots of time!
Charles - 回复 分享
Thank you! Valuable comment!
pzhivulin - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 35
过去 30 天: 128
总计 137,335
