跳转到主内容
MacBook Air 13" Early 2015 Left Speaker Replacement
你所需要的
  1. MacBook Air 13" Early 2015 Left Speaker Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    购买
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 Left Speaker Replacement, Battery: 步骤 3 中的图像 1,1
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  5. MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 5 中的图像 1,1
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 13" Early 2015 Left Speaker Replacement, Left Speaker: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  7. MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 7 中的图像 1,3 MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 7 中的图像 2,3 MacBook Air 13" Early 2015 Left Speaker Replacement: 步骤 7 中的图像 3,3
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
结论
7等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,970 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 46
总计 5,990
