简介
使用本指南更换固态硬盘。
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
使用P5 Pentalobe 螺丝刀将底部的十颗螺丝移除,有下面两种规格:
两个9mm 梅花形螺丝
八个2.6mm梅花形螺丝
把手指插进显示器和底壳之间的缝隙然后向上拉,即可拆下底壳。
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
To add - the slim 1cm tab “nub” is on the centre of the back cover & fits into a hole in the battery frame. I ran my fingers around the whole of the cover to eventually here it click out.
nijafe -
So this is a legit back cover for MacBook Air?
I bought the part and tools from iFixit and followed the directions. The mechanical part went smoothly - maybe 10 minutes to disassemble/replace/reassemble.
Getting Catalina (the current MacOS) to install was not working until I used Cmd-Opt-R (as noted in the OWC paper sheet that came in the box) which brought up the proper installer - I believe from a pre-prepared bootable SD card but it’s hard to say. From there the install succeeded taking ~1.5 hours.
Beware that (a) the install requires a working internet connection for verification and updates, and (b) the system must have been running at least macOs 10.13 (High Sierra) before the install in order to have an EFI BIOS that recognizes the SSD.
Lance Berc - 回复
Thanks for the detailed photos. When repairing equipment, I don’t really like to disassemble plastic parts, they can be damaged, but your screenshots help a lot. For my studies, I am writing an essay comparing the reliability of laptops from various manufacturers and the complexity of their repair, maybe it will be useful for someone to check the essay for plagiarism here essay checker, when comparing different manufacturers, I understood why people love Apple so much. The minimum number of failures. Of course, repairing it in an official service is not cheap, but with the help of such detailed instructions, you can do it yourself and save a lot.
The screwdriver bit to use on these case screws is not named, but I found that my "CR-V 1.2" did the job nicely.
The driver for the screws inside the case are named, as "T5".
抓住连接到电池接口的透明塑料拉片,将其平行于电路板拉向 MacBook Air 的前缘。
how does a person put the battery connector back in?- that is the only thing i’m afraid of touching after putting new fan in.
I found it was possible to put the battery connector back in as the last step, however having gone through that and found it to be a little challenging, I would actually recommend attaching the battery connector before screwing back in the bracket. That way you’ll put a lot less stress on the connector cable.
When you are plugging the connector back in, make sure to give it some extra pressure to make sure it is all the way in. It may look like it’s in but needs to be pushed harder!
After disconnecting the power, you may skip directly to step 18. I don’t know why someone would think it necessary to disconnect all the other stuff. There is no need whatsoever to do so. The more things you disconnect, the more things you risk damaging. Many of the parts in steps 4 through 17 are quite delicate, and easy damaged.
The screw in step 18 is easily accessed without removing even the rubber gasket. Regarding step 18, only remove the screw. (This screw is rather long, with long threads.)
It’s helpful to take photographs of this area before removing the screw, so you’ll know what it’s supposed to look like when you put it back together.
There are only 16 steps in this repair process. I wonder whether you are commenting on a different repair.
What if your battery doesn’t have that clear tab?
Yep, exactly the issue that I have
Where can i buy the battery connector?
Macbook air 2015 battery connector where can I purchase?
拆卸一颗2.9毫米 T5 Torx螺丝钉以移除主板上的固态硬盘。
I'm using a T5 Torx screwdriver to remove the SSD retaining screw but it's simply not working, the screwdriver seems slightly too big and I even tried plyers to grab the ends of the screw and turn it but that didn't budge. Are the screws super tight or something? I can't figure out what I'm doing wrong
I would also like to know that, i have the same problem tried using a standard T5 Torx and the Pentalobe P5 screwdriver, but the both dont work/fit
I ended up using the T5 with a rubber band in between. I wish I would have done this earlier. I stripped a little bit of the screw. You live you learn.
After reassembly, press and hold cmd-opt-R immediately after hitting power button
T4 worked for me.
轻轻抬起SSD的半英寸左右的一端,并与主板平齐拉出来以卸下固态硬盘
Am I able to upgrade my Macbook Air early 2015 from 128Mb SSD to the SSD Samsung 960 (EVO or Pro) 1TB or 2TB?
If so, do a need special adapters?
Is there an adaptor cable or external housing that allows me to transfer the information on my SSD to my other laptop that has a SATA drive?
There are several available at Other World Computing.
I really don’t recommend using M.2 SSD’s!
As someone who services Mac’s I tend to see the failures and I’l warn you I see a lot of these M.2 drives with adapter with problems. As one of the first diagnostic processes I pop in my custom Apple Samsung SSD to see if the system works with it. If it does I recommend the power to replace the SSD.
Dan -
If I’m ordering a 1TB ssd what exactly should I be asking for ?
i looked up a replacement for my 2015 Air and the ssd they sent had the slot in the wrong place. Will I need an adapter?
why did they suggest it would be compatible (it’s an m2)?
Colin Gray - 回复
Seems cheap isn’t good
Colin Gray - 回复
Is the same procedure suitable for a macbook 13” early 2014?
RvS
Hey robert, the procedure is exactly the same for the 2014 MBA! You can check out our MacBook Air 2014 SSD replacement guide to check for yourself.
Shouldn’t you disconnect the battery before removing the old SSD? Guide lacks instructions for this so not sure if necessary/ recommended. I recall HDD upgrade guide for my old MBP 2010 included disconnecting the battery, surely same for MBA?
Yes, always disconnect the battery first before removing other components.
(Edit: I only skimmed, looking for chat about adapters and such. It’s there.. Step 3. At least, it is now. Maybe it was added after your comment) :)
Ashlar -
My mid-2013 Air has crashed to the point of being unrecoverable - I get the folder with a question mark upon startup and there is no disk to recover from when I finally get to disk utility. After a couple phone calls with Apple, they determined they couldn’t do anything. I’m wondering if I can remove my SSD from the laptop, if I can use an adapter cable to make the files accessible via a cable (preferably to USB C) on my new MacBook Air mid-2020. I appreciate the help, thank you.
Jack Tynan - 回复
is there any software updates that need to be done to configure this to work properly or is it a plug and play type of thing?
as long as your on a modern OS version Catalina or higher its plug and play
Dan -
I swapped out a larger (non-OEM) SSD in my MacBook Air. Everything works fine except now when I wake my computer from sleep, I’m just given a black screen and the logon screen doesn’t load. I usually have to force shutdown and restart whenever waking from sleep, kind of annoying. Any hints as to what may be the issue?
Tutorial looks great! My worries are what to do once I have put the laptop back together again. If I swop my 500 GB to a 1 TB SSD (w/o adaptor), can I just start it up with my Time Machine Backup? Or do I need to reinstall Mac OS?
I have a MacBook Air Early 2015, running High Sierra 10.13.6.
Where can I get the adaptor for the ssd. Also if I am taking the ssd from the 2017 air and just trying to read the info on it on a 21 14" mb pro. Is there anything I should know. The 2017 air has got a firmware lock on it. I bought it used for my what's now ,ex. I don't know if she put the firmware password on it or the og owner who I have no way of getting back in touch. His account is no longer active on fb. So im kind of screwed. The only thing I could think of was to remove the ssd and put it in an we enclosure and see if I can read the info on the drive. My ex refuses to give me the pw so it has me curious. I figured I woukd take a look before I wipe it.
Jon Tracey - 回复
欲重组你的设备,按照相反的顺序执行这些指令。
90等其他人完成本指南。
由衷感谢以下译者:
75%
Enrico Shan正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
25条评论
Fairly straight forward once you get the right screwdrivers. Took me less than 10 minutes.
Very simple and straight forward replacement. First-party SSD replacement can be found on ebay (typically removed from parted-out MacBook Airs). Currently they're aren't any third-party parts available.
The Relevant Parts list all has incorrect links. Bait & Switch??
Examples:
"$199.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 256 GB"
Actually supplies: 128GB USED
"$349.95 Macbook Air 11" and 13" (Mid 2013/Early 2014) SSD, 512 GB"
Actually supplies: 256GB USED
Whoops! Looks like we didn't update the details on those parts when we updated the part itself, sorry about that!
How do I clone the content of my current ssd hard drive that I want to upgrade? Basically I want my macbook air ready for use once I install the new ssd drive.
First off, you would need an enclosure with cable that would let you connect the new/replacement ssd/flash to your existing Air using a USB port. Then use Clone Carbon Copy and copy the inner drive to the outside drive. 30 minute process, at most. Then follow this well-done guide.
Phil L -
Hi all.
What is the maximum SSD accepted (and recognized by OSX) for Macbook Air Early 2014 ?
I have 256 GB. Can I go above this ?
ebay_mihai - 回复
you can install what ever you want and your wallet is available to ^^
i have now the 500GB Samsung EVO 970 M.2 NVMe with an adapter installed. more is possible.
M.2 NVMe is the cheapest way to upgrade your MacBook. If you have to much money, you can also buy an OWC SSD (up to 1000$ for 2TB; Samsung 2TB 500$)
Marcel -
Marcel: Would be nice to know what the performance is like.
Which adapter exactly did you use?
Is the Samsung EVO 970 M.2 NVMe slower than the (more expensive) OWC SSD due to the adapter?
I looked into this and was told that the new SSD drives did not play well with this model. Comment ?
Samsung evo 960 and sintech adapter works perfect. 2014 mba plug and play and time machine backup restore.
Did you test the performance?
Hi! I already own this Inland Profession M.2 drive and would love to be able to use it for this project. Is it compatible, and if so, how do I find the proper adapter?
Has anyone had luck upgrading the SSD? I upgraded to the OWC X2 and now after the computer goes into hibernation mode it restarts twice before I can use it. This usually occurs in the mornings…
Hey Will! That’s a fairly common post-SSD-upgrade problem, unfortunately :( Here’s a forum post with a couple troubleshooting options you can try! Really an SSD doesn’t need to “hibernate” like a spinning drive does, so if nothing else works for you, you can always just disable hibernation. Sorry about the trouble!
I bought a Macbook Air 2014 and it didn’t come with an ssd. I ordered an OWC Aura pro x2 ssd and installed it. The Mac had El Capitan installed previously (I saw it on the Ebay listing). The new ssd would not appear in the disk utility menu. In the end I have a Macbook Air that I can’t get an operating software on. Any ideas?
As mentioned above, you need MacOS 10.13 High Sierra (or later).
Normally you would install that first, then install the new SSD.
Have you tried booting from USB on a newer version of MacOS and installing that way?
Same problem to a certain extent. I am trying to upgrade my ssd. Followed all the instructions but once I get to disk utility my hd is not shown. Only thing I am disk0 and OS X Base. Can’t select any options. Can’t install OS or anything else because there is no hard drive to select.
Bonjour, j’ai essayé d’installer un ssd samsung 970 evo plus 500 GB sur mon macbook air début 2014. J’ai tout essayé mais impossible de réinstaller macOS sur la machine, ça plante tout le temps. J’ai tenté de remettre Mojave via le réseau wifi puis j’ai créé une clé usb (8GB) bootable avec Mojave dessus. Je démarre la machine en cliquant alt puis choisi de restauré macOS Mojave en utilisant ma clé. Je choisi la destination, soit le nouvel ssd et ça démarre. Sauf que ça plante toujours. Je précise que mon ssd est formater en macOS étendu (journalisé). Avez-vous une solution car là je ne sais plus quoi faire de plus ?
Merci
Very disappointed with this product since it does not work ; no installation problem ;
no problem as long as it is running, but problems appear when I put it to sleep
when i put it in deep sleep pmset hibernatemode 25 it crashes as soon as i open the hood and it reboot alone 2 times before restartingif i put the hibernatemode 3 it crashes from the moment when he has to use his sleepimage and again he reboot alone 2 times before restarting
whether in high sierra or mojave with my macbook air early 2014 11", 1,7 Ghz intel core i7
response
Thank you for contacting me back! This SSD is compatible with your MacBookAir, regrettably, any NVME SSD will potentially face the same issue. This is due to a connection issue with the logic board to the SSDs. We are working with Apple to resolve this and hope to have a permanent fix soon.
Does iFixit sell the enclosure for this SSD? It look proprietary. I really just need to access the data from a dead computer. Any help appreciated!
une erreur s'est glissée dans la rédaction du "how to" Ayant suivi cette procédure pour installer un 400 GB Aura Pro X2 page 3 vous indiquez l'utilité d un Torx T9 de 2;9. Or il s agit Dun Torx T5 i Pour le reste ce fut assez simple grâce à votre conseil.... merci
Bonjour @sinagot,
Merci de votre remarque et de votre attention. Effectivement, il y avait une erreur dans la traduction. Je l'ai rectifiée. iFixit étant un wiki, n'hésitez pas à corriger vous-même la prochaine fois que vous trouvez une erreur. Merci encore et belle journée à vous !
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - 回复
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - 回复
I thought I could replace my 256 Gb SSD with 512? regards
ola m - 回复
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - 回复
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - 回复
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - 回复
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - 回复
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - 回复
P5 pentalobe screwdrivers are too big! The correct size for these screws are p4 pentalobe. P5 pentalobe was just able, with difficulty, to turn some of the screws. If the screws were at all tight, my p5 was unable to get them out, and started to strip the screws. A p4 screwdriver fit better and removed the screws with ease. (I was using high quality Wiha brand screwdrivers.)
William Skinner - 回复
I had same experience (with MacBook Air 13-inch Mid-2012) … had to get P4, which worked swimmingly
eric -
Very simple installation. The screwdriver heads were exactly what we’re needed, one head for the outside case screws, the other for the screws holding the battery in place. The computer started right up. Now to see how the battery holds up, but I have a good feeling about this!
Dennis Eaton - 回复
My P5 and the T5 worked perfectly with my early 2015 Air 13”! And it is super fast! Thank you iFixit!
Pennny Beach - 回复
The supplied kit and instructions worked perfectly!
Nikolay Andreev - 回复
Comments that the P5 pentalobe are too large are absolutely spot-on. There is no way the P5 pentalobe bit I have will work with the MacBook Air without destroying the screws. Hard target search for P4 pentalobe bit in progress…..
joemoog - 回复
Bonjour j’aimerais changer mon SSD de 128 Go pour en mettre un de 512 Go. Je ne sais pas ce qu’il faut prendre car il faut qu’il soit compatible avec le macbook air A1466. J’aurais vu un Samsung Evo 970 500 Go mais si je ne me trompe pas, il faut un adaptateur.
Merci pour votre aide.
chicco33 - 回复
oui, vous aurez besoin d’un adaptateur, pour completez le changement.
Dan -
The tool kit should include tweezers for re-inserting the battery connector.
Andre Clement - 回复
P5 pentalobe worked perfectly for me. Instructions were spot-on. Antenna connections were a bit fiddly to refit but got them in ok.
michaelquinnell - 回复
Maybe the problem some are experiencing is that the designations are confusing (blame Apple rather than iFixit). the P2 is also known as PL1. The P5 is also known as PL4. The P6 is also known as PL5. So it is possible to mistake the P6 (PL5) for the P5 (PL4), meaning it (P6-PL5) will be too big, while the P5 (PL4) will be just right. Sort of a 3 Bears explanation, but it is very confusing.
Thomas Lewis - 回复
To add to this. In searching for the P5 screwdriver to buy in UK, as far as I can tell, it is also known as
Pentalobe 1.2(mm)
also
P4 = 0.8
P6 = 1.5
Just unscrewed the back case of MacBook Air 13” mid 2011, with no problems using Pentalobe 1.2
nijafe -
I have not replaced a display on the A1369 but have done many A1466 which is a newer 13” model. They seem really similar and its not clear why one needs to remove the logic board to remove the display. The antenna cables on the A1466 dont have to rest under the logic board but can be tucked in the hinge crevice. Cant this same thing be done with the A1369?
Sean Love - 回复
Did mine today - but new battery wasnt charging. Went back in and noticed the battery connector cable was not quite 100% “seated. It was sticking out by less than a millimetre! - you need to give it quite a firm push in to get it seated properly. Otherwise - all ok .
John Brennand - 回复
Just installed on a MacBookAir6,2 (13-inch, Early 2014).
Was very easy.
New iFixit battery looks great so far:
Jonathan Cross - 回复
can you tell me which size of screwdrivers you’ve used to crack it up, please? I have the same model and size,
hawk_lpc -
Screw P5 Pentalobe 1.2
Mario Verlent - 回复
Install went flawlessly. Only challange was reattaching blue tooth antennas. Those sockets are so tiny.
Joel Sebastian - 回复
Installation was a little challenging at first because the instructions on this site did not perfectly match my model (late 2013 to early 2015).
Found this video on YouTube which described the procedure perfectly https://www.youtube.com/watch?v=Lue6lVWh...
Also the Ifixit kit I received was well put together with everything I needed and more. The calibration went perfectly and I am very pleased. Will buy again!!
Donald Niamath - 回复
Gently pulled out connector of old battery, then pressed and held the power switch for 1 minute. Unscrewed and removed the old battery. Pressed and held power switch for 1 minute again. I know from previous work that this helps drain charge from spontaneous recharging as the dielectric recovers. Gently “fine tuned” leads from new battery to connector till connector stuck out at right angle to the edge of battery. Held the battery by the edges and let the connector slide into the socket. Set the battery down and put the screws in all the way. Then checked that the connector was completely seated before tightening the screws. The laptop come on immediately and showed 98% charge and registered normal (checked in “About this Mac”. Very happy to this point. Now for calibration.
Amir Zaidi - 回复
Thank you very much for the guilde. My MBA2011 had reborn !
Billy Wong - 回复
Allow for electrostatics, otherwise you may cook components on the logicboard /motherboard (like I did with one of these!)
See great advice: Electrostatic Discharge
Fletcher Cole - 回复
… und wenn du eines von diesen wirklich kleinen Schräubchen vermisst: bevor du den Boden aufkehrst oder mit einem starken Magneten absuchst, schau mal am seitlichen (magnetischen) Ladekabelanschluss nach … ?
... and if you miss one of these really small screws: before you sweep the floor or search it with a strong magnet, take a look at the (magnetic) charging cable connection on the side … ?
Blatt - 回复
Fot All People ha ing trouble finding their SSD
DONT PRESS CMD +R + POWER
instead press
OPTION+CMD+R +POWER
I just installed Monterrey with WD black sn 770 SSD in m'y macbook air 2015
Albert - 回复
IFixit just had me submit "my story" re. fixing my MacBook Air 2013.
This repair was NOT difficult. The battery is enclosed in a plastic frame. It is NOT glued in like the newer models of Apple laptops. And unlike older laptops, the battery is not totally enclosed in a plastic housing. So once you remove the screws holding the batterie's frame, you can remove the battery.
Follow the instructions. Read the comments. Also read the comments re. installing a new battery.
Good luck. - Eric J.
ECJohansen - 回复
On the back of the laptop, notice that each screw is angled a little bit inward, aiming toward the middle of the laptop. Keep your screwdriver lined up with the screw (angled a bit outward as seen at 01:23 in the video: https://youtu.be/tToAwO6f-SY&t=83). This will help you get a good bite on the screw to get it out and avoid stripping the head of the screw.
Use the same angle when putting each screw back in. If the screw is in line with its hole it should not feel like you are fighting to screw it in. If it does, check your angle and back up a little; you should feel the screw fall into line.
Rich Garella - 回复
shrhh - 回复
