跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2011 Upper Case Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Lower Case: 步骤 1 中的图像 1,1
      在这个步骤中使用的工具:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Shut down and close your computer. Lay it on a soft surface top-side down.
      • Remove the following ten screws:
      • Two 8 mm 5-point Pentalobe screws
      • Eight 2.5 mm 5-point Pentalobe screws
      • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 2 中的图像 1,1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 步骤 3 中的图像 2,2
      • In this step you will disconnect the battery to help avoid shorting out any components during service.
      • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
      • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Solid-State Drive: 步骤 4 中的图像 1,1
      • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 5 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 5 中的图像 2,2
      • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
      • Do not lift the end of the SSD excessively.
      • Pull the drive straight out of its socket and remove it from the logic board.
      • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, I/O Board Cable: 步骤 6 中的图像 1,1
      • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 7 中的图像 1,1
      • Peel the I/O board cable up from the adhesive securing it to the fan.
      添加评论
    3. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 8 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 8 中的图像 2,2
      • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
      • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
      • Remove the I/O board cable.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Fan: 步骤 9 中的图像 1,1
      • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 10 中的图像 1,1
      • Remove the following three screws securing the fan to the upper case:
      • Two 5.2 mm T5 Torx screws
      • One 3.6 mm T5 Torx screw
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 11 中的图像 1,1
      • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 步骤 12 中的图像 1,1
      • Remove the following five screws securing the battery to the upper case:
      • One 6 mm T5 Torx screw
      • Two 2.6 mm T5 Torx screws
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 13 中的图像 1,1
      • Do not touch or squeeze the six lithium polymer cells when handling the battery.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Logic Board: 步骤 14 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement, Logic Board: 步骤 14 中的图像 2,2
      • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
      • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
      • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 15 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 15 中的图像 2,2
      • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
      • Pull the keyboard backlight ribbon cable out of its socket.
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 16 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 16 中的图像 2,2
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
      询问修复机器人
      添加评论
    4. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 17 中的图像 1,1
      • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
      询问修复机器人
      添加评论
    5. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 18 中的图像 1,1
      • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
      • Pry up from beneath the cables.
      询问修复机器人
      添加评论
    6. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 19 中的图像 1,3 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 19 中的图像 2,3 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 19 中的图像 3,3
      • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
      • Remove the small rubber gasket from the corner of the upper case near the display data cable.
      询问修复机器人
      添加评论
    7. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 20 中的图像 1,1
      • While holding the lock away from the socket, gently pull the display data cable out of its socket.
      • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
      询问修复机器人
      添加评论
    8. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 21 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 21 中的图像 2,2
      • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
      添加评论
    9. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 22 中的图像 1,1
      • Gently de-route the antenna cables from the slot cut into the logic board.
      询问修复机器人
      添加评论
    10. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 23 中的图像 1,1
      • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
      询问修复机器人
      添加评论
    11. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 24 中的图像 1,1
      • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Display Assembly: 步骤 25 中的图像 1,1
      • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 26 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 26 中的图像 2,2
      • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
      • Be sure you are prying up on the retaining flap, not the socket itself.
      • Pull the microphone ribbon cable straight out of its socket.
      询问修复机器人
      添加评论
    3. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 27 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 27 中的图像 2,2
      • De-route the left speaker cable from the notch cut into the I/O board.
      • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
      • Pry up from beneath the wires.
      询问修复机器人
      添加评论
    4. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 28 中的图像 1,1
      • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
      • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
      询问修复机器人
      添加评论
    5. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 29 中的图像 1,1
      • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
      询问修复机器人
      添加评论
    6. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 30 中的图像 1,1
      • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
      询问修复机器人
      添加评论
    7. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 31 中的图像 1,3 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 31 中的图像 2,3 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 31 中的图像 3,3
      • Peel up the six cable loops securing the antenna cables to the upper case.
      • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
      • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
      • Repeat this for all of the retaining loops.
      添加评论
    8. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 32 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 32 中的图像 2,2
      • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
      添加评论
    9. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 33 中的图像 1,1
      • Open the display until it is perpendicular to the upper case and place it on a table as shown.
      • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
      询问修复机器人
      添加评论
    10. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 34 中的图像 1,1
      • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
      • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
      询问修复机器人
      添加评论
    11. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 35 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 35 中的图像 2,2
      • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
      • Once the two display hinges have cleared the upper case, remove the display and set it aside.
      询问修复机器人
      添加评论
    1. MacBook Air 11" Mid 2011 Upper Case Replacement, Upper Case: 步骤 36 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement, Upper Case: 步骤 36 中的图像 2,2
      • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
      • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
      • Remove the right speaker from the upper case.
      询问修复机器人
      添加评论
    2. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 37 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 37 中的图像 2,2
      • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
      • Remove the left speaker from the upper case.
      添加评论
    3. MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 38 中的图像 1,2 MacBook Air 11" Mid 2011 Upper Case Replacement: 步骤 38 中的图像 2,2
      • Use the tip of a spudger to pry the microphone away from the side of the upper case.
      • Remove the microphone from the upper case.
      • Upper case remains.
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 26
总计 5,781
