跳转到主内容
加入维修社区 - 创建账户
MacBook Air 11" Mid 2011 Solid-State Drive Replacement
你所需要的
  1. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    询问修复机器人
  3. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 步骤 3 中的图像 1,2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Battery: 步骤 3 中的图像 2,2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2011 Solid-State Drive Replacement, Solid-State Drive: 步骤 4 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
    询问修复机器人
  5. MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 步骤 5 中的图像 1,2 MacBook Air 11" Mid 2011 Solid-State Drive Replacement: 步骤 5 中的图像 2,2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
结论
116等其他人完成本指南。
16指南评论
Note: if you're installing a blank SSD, you'll want to format it with Disk Utilities) before the OS X installer will recognize it.
aaronmiller - 回复 分享
Could not have been any easier, with this guide.
Thank you very much!
916sp - 回复 分享
is it possible to replace an 128 GB Solid State Drive with an 240 GB? (MacBook Air, 11", Mid 2011)
zimmermatthias - 回复 分享
Does anyone know if the Samsung 960 pro 512gb m.2 drive is compatible with this machine?
Mark - 回复 分享
No, is not, I just bought a 1TB Samsung 960 EVO m.2 and had to return it, for not being compatible. (is smaller and the pin-out is not the same)
fjlbandeira - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 82
过去 30 天: 454
总计 256,353
