跳转到主内容
Mac mini Late 2014 Logic Board Replacement
你所需要的
  1. Mac mini Late 2014 Logic Board Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • The bottom cover is clipped onto three screw posts.
    • Pry near, but not right on the screw posts.
  2. Mac mini Late 2014 Logic Board Replacement: 步骤 2 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 2 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the bottom cover up off of the Mac mini.
  3. Mac mini Late 2014 Logic Board Replacement: 步骤 3 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 3 中的图像 2,2
    • Lift and remove the bottom cover.
  4. Mac mini Late 2014 Logic Board Replacement, Antenna Plate: 步骤 4 中的图像 1,1
    • Remove the following TR6 screws from the antenna plate:
    • Three 4.1 mm screws
    • Three 1.9 mm screws
  5. Mac mini Late 2014 Logic Board Replacement: 步骤 5 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Do not completely remove the antenna plate; it is still connected to the Mac mini by an antenna cable.
    • With the I/O ports facing you, flip the antenna plate to the right to allow access to the antenna cable connector.
  6. Mac mini Late 2014 Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3.4 mm T6 screw and washer from the antenna cable.
    • Be careful not to lose the washer when removing the screw.
  7. Mac mini Late 2014 Logic Board Replacement: 步骤 7 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 7 中的图像 2,2
    • Use the point of a spudger to lift the antenna connector straight up off its socket on the airport card.
  8. Mac mini Late 2014 Logic Board Replacement: 步骤 8 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 8 中的图像 2,2
    • Carefully pull the antenna cable out from the gap between the power supply and case.
  9. Mac mini Late 2014 Logic Board Replacement: 步骤 9 中的图像 1,1
    • Remove the antenna plate from the Mac mini.
  10. Mac mini Late 2014 Logic Board Replacement, Fan Assembly: 步骤 10 中的图像 1,1
    • Remove the two 12 mm T6 screws from the fan.
    • Loosen the 27 mm T6 captive screw–it will get removed with the fan assembly.
  11. Mac mini Late 2014 Logic Board Replacement: 步骤 11 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 11 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 11 中的图像 3,3
    • The fan connector is trapped under the edge of the fan and cannot be disconnected until the fan is moved.
    • Do not attempt to remove the fan entirely.
    • Lift the fan straight up to free the captive screw from its hole in the logic board.
    • Pull the fan away from the SSD until you can easily access the fan connector.
  12. Mac mini Late 2014 Logic Board Replacement: 步骤 12 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 12 中的图像 2,2
    • Use the point of a spudger to lift the fan connector straight up out of its socket on the logic board.
  13. Mac mini Late 2014 Logic Board Replacement: 步骤 13 中的图像 1,1
    • Remove the fan from the Mac mini.
  14. Mac mini Late 2014 Logic Board Replacement, Logic Board Assembly: 步骤 14 中的图像 1,1
    • Remove the 2.6 mm T6 screw securing the SATA cable connector bracket.
  15. Mac mini Late 2014 Logic Board Replacement: 步骤 15 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 15 中的图像 2,2
    • Remove the SATA cable connector bracket.
  16. Mac mini Late 2014 Logic Board Replacement: 步骤 16 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 16 中的图像 2,2
    • Use the flat end of a spudger to lift the SATA cable connector up off of its socket on the logic board.
  17. Mac mini Late 2014 Logic Board Replacement: 步骤 17 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 17 中的图像 2,2
    • Use the tip of a spudger to disconnect the IR sensor cable connector by prying it straight up from its socket.
  18. Mac mini Late 2014 Logic Board Replacement: 步骤 18 中的图像 1,1
    • The following three steps only apply to Mac minis equipped with a PCIe SSD. Skip the next three steps if your Mac mini only has a hard drive.
    • Remove the two 2.6 mm T6 screws securing the PCIe SSD cable bracket.
  19. Mac mini Late 2014 Logic Board Replacement: 步骤 19 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 19 中的图像 2,2
    • Remove the PCIe SSD cable bracket.
  20. Mac mini Late 2014 Logic Board Replacement: 步骤 20 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 20 中的图像 2,2
    • Lift the PCIe SSD connector up off its socket.
  21. Mac mini Late 2014 Logic Board Replacement: 步骤 21 中的图像 1,1
    • Remove the single 16 mm T6 screw securing the logic board.
  22. Mac mini Late 2014 Logic Board Replacement: 步骤 22 中的图像 1,1
    在这个步骤中使用的工具:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure the rods make contact with the case under the logic board before proceeding.
  23. Mac mini Late 2014 Logic Board Replacement: 步骤 23 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 23 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 23 中的图像 3,3
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the removal tool makes contact with the opening in the rear case.
    • Remove the Mac mini Logic Board Removal tool.
  24. Mac mini Late 2014 Logic Board Replacement: 步骤 24 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 24 中的图像 2,2
    • Pull the DC-In cable connector straight out of its socket on the logic board.
  25. Mac mini Late 2014 Logic Board Replacement: 步骤 25 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 25 中的图像 2,2
    • Carefully slide the logic board assembly out of the Mac mini, minding any cables that may get caught.
  26. Mac mini Late 2014 Logic Board Replacement, Heat Sink: 步骤 26 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement, Heat Sink: 步骤 26 中的图像 2,2
    • Remove the following screws securing the heat sink to the logic board:
    • Four 8.6 mm T8 Torx screws
    • One 2.9 mm T6 Torx screw
    • Be careful not to lose the springs held beneath each of the T8 heat sink screws, they may fall off of the screws as you remove them.
    • During reassembly, tighten these screws evenly to ensure the heat sink stays flat against the CPU.
  27. Mac mini Late 2014 Logic Board Replacement: 步骤 27 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 27 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 27 中的图像 3,3
    • Remove the heat sink from the logic board.
    • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
    • Don't reassemble your Mac mini without applying a new layer of thermal paste.We have a thermal paste guide to show you how.
  28. Mac mini Late 2014 Logic Board Replacement, I/O Bezel: 步骤 28 中的图像 1,1
    • Remove the following T6 Torx screws from the I/O port antenna cables:
    • Three 2.8 mm screws with washers
    • One 3.4 mm screw
    • One 2.7 mm screw
  29. Mac mini Late 2014 Logic Board Replacement: 步骤 29 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 29 中的图像 2,2
    • Use the point of a spudger to lift the power switch cable connector straight up out of its socket on the logic board.
  30. Mac mini Late 2014 Logic Board Replacement: 步骤 30 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 30 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 30 中的图像 3,3
    • Use the point of a spudger to lift the antenna connectors up off of their sockets on the AirPort card.
  31. Mac mini Late 2014 Logic Board Replacement: 步骤 31 中的图像 1,1
    • Remove the four 2.7 mm T6 Torx screws holding the I/O bezel to the logic board.
  32. Mac mini Late 2014 Logic Board Replacement: 步骤 32 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 32 中的图像 2,2
    • Remove the foam bumper from between the I/O bezel and USB ports.
  33. Mac mini Late 2014 Logic Board Replacement: 步骤 33 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 33 中的图像 2,2
    • Pull the I/O bezel off of the logic board, minding any cables that may get caught.
    • Try not to handle the small steel tabs on the logic board and I/O bezel, as oils from your fingers may cause interference issues. Before installing the logic board assembly, clean the metal tabs to remove any oils transferred during the removal process.
  34. Mac mini Late 2014 Logic Board Replacement, Logic Board: 步骤 34 中的图像 1,1
    • Remove the following T6 Torx screws securing the speaker to the logic board:
    • One 3.6 mm screw
    • One 3.6 mm large headed screw
  35. Mac mini Late 2014 Logic Board Replacement: 步骤 35 中的图像 1,2 Mac mini Late 2014 Logic Board Replacement: 步骤 35 中的图像 2,2
    • Do not attempt to remove the speaker entirely as it is still attached to the logic board.
    • Nudge the speaker gently out of the way to allow access to the speaker's connector.
  36. Mac mini Late 2014 Logic Board Replacement: 步骤 36 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 36 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 36 中的图像 3,3
    • Use the flat end of a spudger to carefully lift the speaker connector up out of its socket on the logic board.
    • Remove the speaker from the logic board.
  37. Mac mini Late 2014 Logic Board Replacement: 步骤 37 中的图像 1,1
    • Remove the 2.7 mm T5 screw securing the AirPort card.
  38. Mac mini Late 2014 Logic Board Replacement: 步骤 38 中的图像 1,3 Mac mini Late 2014 Logic Board Replacement: 步骤 38 中的图像 2,3 Mac mini Late 2014 Logic Board Replacement: 步骤 38 中的图像 3,3
    • Lift the free end of the AirPort card enough to grasp it by the edges.
    • Pull the AirPort card straight out of its socket on the logic board and remove it from the Mac Mini.
结论
17等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,074 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,781篇指南
4指南评论
is there any internal battery on the logic board..
sokratis162 - 回复
Are all Mac Mini cases the same from 2011 on? Could I take out my 2011 guts and put in one from 2014?
jbasa - 回复
hello a question as it is called the piece that contains the hard disk?
Miguel - 回复
It is called a hard drive tray or hard drive carrier. You can find the guide to remove it here.
Arthur Shi -
添加评论
浏览统计数据:
过去 24 小时: 121
过去 7 天: 657
过去 30 天: 2,114
总计 45,646
