跳转到主内容
加入维修社区 - 创建账户
Mac mini Late 2012 RAM Replacement
你所需要的
  1. Mac mini Late 2012 RAM Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Mac mini Late 2012 RAM Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
    添加评论
  2. Mac mini Late 2012 RAM Replacement: 步骤 2 中的图像 1,1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
    添加评论
  3. Mac mini Late 2012 RAM Replacement, RAM: 步骤 3 中的图像 1,2 Mac mini Late 2012 RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
    添加评论
结论
取消:我没有完成这个指南。
186等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,665篇指南
7指南评论
So if I were to replace the Ram on my mac mini I would only have the option to choose between the 2 gb chip or the 4gb chip? I know dumb question lol.
Bianca - 回复 分享
2x8GB is as much as those motherboards can handle.
Kevin Shaffer - 回复 分享
Dear everyone,
Does this mac mini accept :
KINGSTON DDR3 PC3-12800 - 2 x 4 Go (8 Go) 1600 MHZ - CAS 10 - HyperX Fury Black Series
Thank you.
Marouane - 回复 分享
I always consult Crucial's memory configuration tool. For a late-2012 Mac mini, see http://www.crucial.com/usa/en/compatible....
According to them, this Mac can go up to 16GB (2 SO-DIMMs of 8GB each). The SO-DIMMs should be DDRL3L-1600 (DDR3L PC3L-12800, CL=11, unbuffered, non-ECC, DDR3L-1600, 1.35v)
The SO-DIMMs you mentioned seem like they should be compatible (CL=10 should work fine in a computer that can accept CL=11). But I would only buy from a vendor that has a compatibility guarantee. If there's a problem, I would want to be able to return them for a refund.
David Charlap - 回复 分享
The SODIMMs don't need to be low voltage DDR3L (i.e. 1.35 volt). In fact Apple recommends (https://support.apple.com/en-gb/HT202593) regular 1.5 volt DDR3 and most late 2012 Mac Minis were shipped with it. So is Crucial wrong? The truth is that either will work.
John Morley - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 15
过去 7 天: 65
过去 30 天: 274
总计 151,517
