跳转到主内容
加入维修社区 - 创建账户
Mac mini (2024) Front USB-C Ports Replacement
你所需要的
    1. Mac mini (2024) Front USB-C Ports Replacement, Before you begin: 步骤 1 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Before you begin: 步骤 1 中的图像 2,2
      • Fully shut down your Mac mini and unplug all cables from it.
      • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
      添加评论
    1. Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 步骤 2 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 步骤 2 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Create a gap: 步骤 2 中的图像 3,3
      • Using the Jimmy or other metal tools during this step could scratch the aluminum chassis; however, it's the simplest way to perform this step. Follow the alternate instructions to avoid scratching the aluminum.
      • Insert a Jimmy into the gap between the bottom cover and the chassis.
      • Pry up the bottom cover to create a gap.
      • Alternatively, you can insert the point of a spudger into one of the plastic vent holes and pry up to create a gap big enough to insert an opening pick into.
      • Keep the Jimmy inserted under the bottom cover.
      添加评论
    2. Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
      • Insert an opening pick into the gap created by the Jimmy.
      • Remove the Jimmy.
      询问修复机器人
      添加评论
    3. Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 步骤 4 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 步骤 4 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Release the pins: 步骤 4 中的图像 3,3
      • Slide the opening pick along the bottom cover until you feel it snag on a pin.
      • There are four pins total—one at each corner of the bottom cover.
      • Twist the pick to lift the pin out of its slot.
      添加评论
    4. Mac mini (2024) Front USB-C Ports Replacement: 步骤 5 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement: 步骤 5 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement: 步骤 5 中的图像 3,3
      • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining pins.
      • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
      • During reassembly, press along the perimeter of the bottom until you hear and feel all four pins click back into place.
      添加评论
    5. Mac mini (2024) Front USB-C Ports Replacement: 步骤 6 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 6 中的图像 2,2
      • Don't remove the bottom cover, as it's still connected to the Mac mini with a cable.
      • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
      添加评论
    6. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: 步骤 7 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the power button: 步骤 7 中的图像 2,2
      • The power button cable is very fragile! You don't have to disconnect it to access the internals— but it will require you to keep the bottom cover propped up.
      • To disconnect the cable and remove the bottom cover, follow the next two steps.
      • If you don't disconnect the cable, prop up the bottom cover to prevent straining the cable and skip the next two steps.
      • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
      添加评论
    7. Mac mini (2024) Front USB-C Ports Replacement, Remove the bottom cover: 步骤 8 中的图像 1,1
      • Remove the bottom cover.
      添加评论
    1. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: 步骤 9 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate screws: 步骤 9 中的图像 2,2
      在这个步骤中使用的工具:
      FixMat
      $36.95
      • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
      • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
      • Eight 3.4 mm‑long screws
      • Four 2.4 mm‑long screws
      添加评论
    2. Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 步骤 10 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 步骤 10 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Separate the inner plate: 步骤 10 中的图像 3,3
      • Insert the point of a spudger into one of the clips' slots on the inner plate.
      • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
      询问修复机器人
      添加评论
    3. Mac mini (2024) Front USB-C Ports Replacement: 步骤 11 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 11 中的图像 2,2
      • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
      • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
      询问修复机器人
      添加评论
    4. Mac mini (2024) Front USB-C Ports Replacement: 步骤 12 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement: 步骤 12 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement: 步骤 12 中的图像 3,3
      • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
      • Lift the inner plate and flip it over to expose the wireless module cable.
      询问修复机器人
      添加评论
    5. Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 步骤 13 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 步骤 13 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the wireless module cover: 步骤 13 中的图像 3,3
      • Use one hand to secure the wireless module during this step.
      • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
      添加评论
    6. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 步骤 14 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 步骤 14 中的图像 2,2
      • Remove the wireless module cover.
      • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
      添加评论
    7. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: 步骤 15 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the wireless module: 步骤 15 中的图像 2,2
      • Insert the point of a spudger under one of the short edges of the wireless module press connector.
      • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
      • Pry up to disconnect the wireless module.
      添加评论
    8. Mac mini (2024) Front USB-C Ports Replacement, Remove the inner plate: 步骤 16 中的图像 1,1
      • Remove the inner plate.
      添加评论
    1. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: 步骤 17 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the fan screws: 步骤 17 中的图像 2,2
      • If you're following this guide to clean your fan, this is a good time to do so.
      • Remove the four screws securing the fan:
      • Two 2.4 mm‑long Torx Plus 3IP screws
      • Two 7.9 mm‑long Torx Plus 5IP screws
      添加评论
    2. Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 步骤 18 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 步骤 18 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Reposition the fan: 步骤 18 中的图像 3,3
      • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
      • Let the fan rest on the chassis and heat sink.
      添加评论
    3. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 步骤 19 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 步骤 19 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the fan: 步骤 19 中的图像 3,3
      • Use tweezers to peel back the tape covering the fan ZIF connector.
      添加评论
    4. Mac mini (2024) Front USB-C Ports Replacement: 步骤 20 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 20 中的图像 2,2
      • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
      添加评论
    5. Mac mini (2024) Front USB-C Ports Replacement: 步骤 21 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 21 中的图像 2,2
      • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
      添加评论
    6. Mac mini (2024) Front USB-C Ports Replacement, Remove the fan: 步骤 22 中的图像 1,1
      • Remove the fan.
      询问修复机器人
      添加评论
    1. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: 步骤 23 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker screws: 步骤 23 中的图像 2,2
      • Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
      • Two 4.1 mm‑long screws
      • One 3.7 mm‑long screw
      询问修复机器人
      添加评论
    2. Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 步骤 24 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 步骤 24 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Reposition the speaker: 步骤 24 中的图像 3,3
      询问修复机器人
      添加评论
    3. Mac mini (2024) Front USB-C Ports Replacement: 步骤 25 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 25 中的图像 2,2
      • Pull the speaker over the edge of the chassis to expose its cable and its connector.
      • Rest the speaker on the edge of the chassis.
      询问修复机器人
      添加评论
    4. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 步骤 26 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 步骤 26 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the speaker: 步骤 26 中的图像 3,3
      • Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
      询问修复机器人
      添加评论
    5. Mac mini (2024) Front USB-C Ports Replacement, Remove the speaker: 步骤 27 中的图像 1,1
      • Remove the speaker.
      询问修复机器人
      添加评论
    1. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: 步骤 28 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port cover screws: 步骤 28 中的图像 2,2
      • Remove the four screws securing the USB-C port cover:
      • Three 2.2 mm‑long Torx Plus 3IP screws
      • One 9.2 mm‑long Torx Plus 8IP screw
      询问修复机器人
      添加评论
    2. Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 步骤 29 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Remove the cover: 步骤 29 中的图像 2,2
      • Use tweezers, or your fingers, to remove the front USB-C port cover.
      询问修复机器人
      添加评论
    3. Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: 步骤 30 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement, Disconnect the front USB-C ports: 步骤 30 中的图像 2,2
      • Use the point of a spudger to pry up and disconnect the front USB-C ports press connector.
      询问修复机器人
      添加评论
    4. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 步骤 31 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 步骤 31 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C port screws: 步骤 31 中的图像 3,3
      • Use a Torx Plus 3IP screwdriver to remove the four 4.7 mm‑long screws securing the two front USB-C ports.
      • If you aren't using a flexible adapter, make sure your screwdriver is as parallel with the screw as possible. Apply constant force against the screw to avoid stripping.
      询问修复机器人
      添加评论
    5. Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 步骤 32 中的图像 1,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 步骤 32 中的图像 2,3 Mac mini (2024) Front USB-C Ports Replacement, Remove the front USB-C ports: 步骤 32 中的图像 3,3
      • Use the point of a spudger to pry the front USB-C ports from their recesses in the chassis.
      • During reassembly, gently press the USB-C ports into their recesses until they click into place.
      询问修复机器人
      添加评论
    6. Mac mini (2024) Front USB-C Ports Replacement: 步骤 33 中的图像 1,2 Mac mini (2024) Front USB-C Ports Replacement: 步骤 33 中的图像 2,2
      • Pull the front USB-C ports out of the chassis and remove it.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
247,177 声望
创作了1,203篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了64,376篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 28
过去 30 天: 134
总计 2,796
