跳转到主内容
加入维修社区 - 创建账户
Mac Pro First Generation RAM Replacement
    1. Mac Pro First Generation RAM Replacement, Case Panel: 步骤 1 中的图像 1,1
      • Lift the lever to unlock the case.
      询问修复机器人
      添加评论
    2. Mac Pro First Generation RAM Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      询问修复机器人
      添加评论
    1. Mac Pro First Generation RAM Replacement, RAM: 步骤 3 中的图像 1,1
      • Locate the two RAM trays at the bottom of the Mac Pro.
      询问修复机器人
      添加评论
    2. Mac Pro First Generation RAM Replacement: 步骤 4 中的图像 1,2 Mac Pro First Generation RAM Replacement: 步骤 4 中的图像 2,2
      • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
      • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
      询问修复机器人
      添加评论
    3. Mac Pro First Generation RAM Replacement: 步骤 5 中的图像 1,3 Mac Pro First Generation RAM Replacement: 步骤 5 中的图像 2,3 Mac Pro First Generation RAM Replacement: 步骤 5 中的图像 3,3
      • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
      • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
22等其他人完成本指南。
Andrew Kim
于10/12/14注册
1,263 声望
创作了3篇指南
团队
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G24
4 名成员
创作了60篇指南
2指南评论
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - 回复 分享
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 74
总计 22,154
