此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
进入并拆卸电源的过程相对直接,需要使用一把 2 mm 六角螺丝刀。
你所需要的
使用 2 mm Phillips 螺丝刀拧下标记出的 4 颗 6-32 六角螺丝。
请注意,Mac Pro 1,1 到 3,1 的电源单元与 Mac Pro 4,1 和 5,1 的电源单元有所不同。
对于 Mac Pro(2008 年初/9 年初),也称为 MacPro3,1,其电源螺丝是 2.5 mm 内六角螺丝,而非 T-10。此外,必须先拆下光驱后面的盖板(2 颗十字螺丝),以露出电源线连接器;在取出电源之前,必须断开这些连接器并将其滑到风扇下方。
要重新组装设备,请按相反顺序执行这些说明。
79等其他人完成本指南。
23指南评论
15 min power on after off
Manish Kumar - 回复 分享
Doesn't work for a micron. Step 6 is impossible. Can't get the power supply out of its place more than a few centimeters. The side closest to the backplate of the casing can't come up only some millimeters, while also the fixed!! power cord is a serious obstruction.
Moreover there are nowhere cover plates left, so this is not a comparable situation as described in step 7.
My last remark should be forgotten. The power cord has been connected to the Mac pro to give the impression that it's mounted fixedly to the power supply. But if you pull with very much force (an attempt of despair), it then again appears to be a 3-hole connector like is the case for common computers. If you don't know these systems, this is very treacherous.
