跳转到主内容
加入维修社区 - 创建账户
Mac Pro First Generation Optical Drive Replacement
你所需要的
    1. Mac Pro First Generation Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
      • Lift the lever to unlock the case
      询问修复机器人
      添加评论
    2. Mac Pro First Generation Optical Drive Replacement: 步骤 2 中的图像 1,1
      • Remove the side panel of the Mac Pro
      询问修复机器人
      添加评论
    3. Mac Pro First Generation Optical Drive Replacement: 步骤 3 中的图像 1,3 Mac Pro First Generation Optical Drive Replacement: 步骤 3 中的图像 2,3 Mac Pro First Generation Optical Drive Replacement: 步骤 3 中的图像 3,3
      • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
      询问修复机器人
      添加评论
    4. Mac Pro First Generation Optical Drive Replacement: 步骤 4 中的图像 1,1
      • Firmly hold each of the two connectors and pull them out of their respective sockets.
      询问修复机器人
      添加评论
    5. Mac Pro First Generation Optical Drive Replacement: 步骤 5 中的图像 1,2 Mac Pro First Generation Optical Drive Replacement: 步骤 5 中的图像 2,2
      • Unscrew the shown two 6-32 type screws on each side of the optical drive.
      询问修复机器人
      添加评论
    6. Mac Pro First Generation Optical Drive Replacement: 步骤 6 中的图像 1,2 Mac Pro First Generation Optical Drive Replacement: 步骤 6 中的图像 2,2
      • Firmly grasp the optical drive and pull it out of its enclosure.
      添加评论
结论
取消:我没有完成这个指南。
21等其他人完成本指南。
Derek Chan
于10/13/14注册
1,428 声望
撰写一个指南
团队
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G24
4 名成员
创作了60篇指南
10指南评论
Thanks! It had been a long time since I'd been inside my towers! Easy-peasy!
Janie Wilson-Cook - 回复 分享
I am having problems with the new optical drive not being able to eject and close without my help. Any thoughts?
footeking - 回复 分享
Did you take off the front of the tray?
nbeijer - 回复 分享
Awesome!!! Worked like a charm! Drive is totally busted. Do you have a link or a suggestion for an optical drive for a late 2009 Mac pro? Thanks either way!
Jay Haser - 回复 分享
The unit holding the optical drive will NOT pull out at all and I and really pulling on it and wiggling it. All other videos show it popping out with little force. What am I doing wrong?
pipevape - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 128
总计 18,963
