跳转到主内容
加入维修社区 - 创建账户
Mac Pro First Generation GPU Replacement
    1. Mac Pro First Generation GPU Replacement, Case Panel: 步骤 1 中的图像 1,1
      • Lift the lever to unlock the case.
      询问修复机器人
      添加评论
    2. Mac Pro First Generation GPU Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      询问修复机器人
      添加评论
    1. Mac Pro First Generation GPU Replacement, GPU (Graphics Card): 步骤 3 中的图像 1,1
      • Locate the graphics card in the open panel side of your Mac Pro.
      询问修复机器人
      添加评论
    2. Mac Pro First Generation GPU Replacement: 步骤 4 中的图像 1,3 Mac Pro First Generation GPU Replacement: 步骤 4 中的图像 2,3 Mac Pro First Generation GPU Replacement: 步骤 4 中的图像 3,3
      • Unscrew the two thumb screws by twisting counterclockwise using your fingers until the slide lock is released.
      • Remove the slide lock.
      询问修复机器人
      添加评论
    3. Mac Pro First Generation GPU Replacement: 步骤 5 中的图像 1,3 Mac Pro First Generation GPU Replacement: 步骤 5 中的图像 2,3 Mac Pro First Generation GPU Replacement: 步骤 5 中的图像 3,3
      • Push up on the clip directly behind the graphics card to release it from its slot.
      • Slide the graphics card out of the slot using both hands by firmly holding the corners of the top of the card as shown.
      • Handle the card only by its edges. Don't touch any exposed components or connectors.
      添加评论
结论
取消:我没有完成这个指南。
23等其他人完成本指南。
Andrew Kim
于10/12/14注册
1,263 声望
创作了3篇指南
团队
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014 的会员
CPSU-MANESS-F14S6G24
4 名成员
创作了60篇指南
8指南评论
I have a first generation Mac Pro (1,1 – 2 x 3GHz Dual-Core Intel Xeon) that I purchased in November 2007.
I still love it.
THANK YOU for your valuable User Guides, and parts replacement guides!
David R Purnell - 回复 分享
Hi, I just installed Mac OS X High Sierra in my 2010 Mac Pro. The first monitor is active with the ATI Radeon HD5770. However the #2 screen is inactive with its ATI Radeon HD3870. Should I get another HD5770 or a different card so I can use the second screen?
Robert Lloyd - 回复 分享
For starters this is the first generation forum while your 2010 is a fifth generation model.
Nevertheless I had an interesting situation with the 5770 in a first gen machine that only ran under strange circumstances—a situation wroth sharing nevertheless.:
Ati Radeon X1900Xt had to be installed on bay 1 for the 5770 to work on bay 4
But for your situation, the question is: does the 3870 work standalone in its bay if the 5770 is taken out completely?
And if you swap the graphics cards into each others’ position, what’s the result?
allenwilson33 - 回复 分享
Hi. My 1st Gen Mac Pro is maxed out with OS X Lion 10.7. I heard I may be able to make it a 5th Gen by switching a chip. Is anyone familiar with this?
Harold L. Watkins - 回复 分享
Hi, I have a first generation MacBook Pro which is maxed out with OS X Lion 10.7. I heard I may be able to upgrade it to a generation 5 by switching out a chip. Is anyone familiar with this?
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 92
总计 23,980
