跳转到主内容
MSI MS-1782 Cooling Assembly Replacement
你所需要的
  1. MSI MS-1782 Cooling Assembly Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove five 6.6 mm screws from the edges of the bottom cover using a JIS #1 screwdriver.
    • Remove one 5.6 mm screw from the center of the bottom cover using a JIS #1 screwdriver.
  2. MSI MS-1782 Cooling Assembly Replacement: 步骤 2 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 2 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 2 中的图像 3,3
    • Use an iFixit opening pick to unclip the bottom cover.
    • It is ok to run the picks along the edges since there is nothing connected to the bottom cover. It is easier to start from the sides and then work your way forward.
    • After unclipping the bottom case, pull from the back of the laptop upwards using the lip of the bottom case as a handle.
  3. MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 步骤 3 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 步骤 3 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement, Cooling Assembly: 步骤 3 中的图像 3,3
    • Loosen the captive screw on the left side of the left fan using a JIS #2 screwdriver.
    • Remove the 5.1 mm screw on the right side of the left fan using a JIS #2 screwdriver.
  4. MSI MS-1782 Cooling Assembly Replacement: 步骤 4 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 4 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 4 中的图像 3,3
    • Gently detach the fan connector.
    • Remove the fan by lifting it out of its housing.
    • Be sure to handle the wire delicately; if not it will break.
  5. MSI MS-1782 Cooling Assembly Replacement: 步骤 5 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 5 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 5 中的图像 3,3
    • Loosen the captive screw on the top of the right fan using a JIS #2 screwdriver.
    • Remove the 3.6 mm screw on the bottom of the right fan using a JIS #2 screwdriver.
  6. MSI MS-1782 Cooling Assembly Replacement: 步骤 6 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 6 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 6 中的图像 3,3
  7. MSI MS-1782 Cooling Assembly Replacement: 步骤 7 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 7 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 7 中的图像 3,3
    • Loosen the eight captive screws holding the heat sink in place using a JIS #2 screwdriver.
    • Be sure to follow the numbers that are next to the screws on the heatsink. This evenly removes pressure on the components when removing the heatsink.
  8. MSI MS-1782 Cooling Assembly Replacement: 步骤 8 中的图像 1,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 8 中的图像 2,3 MSI MS-1782 Cooling Assembly Replacement: 步骤 8 中的图像 3,3
    • Gently lift the heat sink and then pull forwards towards you.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 253
