跳转到主内容
加入维修社区 - 创建账户
MGN Linear Guide
  1. MGN Linear Guide, Linear Rail Inspection: 步骤 1 中的图像 1,2 MGN Linear Guide, Linear Rail Inspection: 步骤 1 中的图像 2,2
    • Inspect your linear rails. Make sure there is a red stopper in the screw holes on each end of the linear rail. I would recommend you leave these in until you're ready to mount them to the frame
    • The carriage should slide along the rail with little force required. I don't have the preload information on these but it's not uncommon to have to apply slight downward force on the carriage for it to slide smoothly
    • There should be a small gap on the along the bearing channel
    • Teardown
    询问修复机器人
    添加评论
    • The MGN carriage comes with manufacture lube on them. The carriage should slide along the rail with little force required. If you feel resistance along the rail or hear what sounds like grinding you should clean the rail guides and the MGN carriage
    询问修复机器人
    添加评论
  2. MGN Linear Guide, What kind of lube do I use?: 步骤 3 中的图像 1,1
    • There's been many discussion about what type of lube to use. First off DO NOT use WD40, JB80 or similar. These are penetrating solvents. These are not to be used as a lubricant.
    • The MGN carriage comes with manufacture lube on them. The carriage should slide along the rail with little force required. I don't have the preload information on these but it's not uncommon to have to apply slight downward force on the carriage for it to slide smoothly
    询问修复机器人
    添加评论
  3. MGN Linear Guide, Removing Stock Grease: 步骤 4 中的图像 1,3 MGN Linear Guide, Removing Stock Grease: 步骤 4 中的图像 2,3 MGN Linear Guide, Removing Stock Grease: 步骤 4 中的图像 3,3
    • Cheap Chinese linear rails are often coated with a thick grease that prevents rust and corrosion. However this prevents the carriage from traveling smoothly.
    • Do not use any magnetic tools on the ball bearings. This will magnetize the balls causing more friction.
    • Remove the 2 screws and the rubber seal on both sides of the carriage block.
    • Using a small flat head screwdriver to nudge the retaining wire out if it's groove.
    • The retaining wire needs to bent slightly in order to remove it. Take care to not bend it too much.
    • At this point the ball bearings are free to fall out so when you remove the retaining wire have a container to put the bearings in ready.
    • There should be 66 ball bearings.
    询问修复机器人
    添加评论
  4. MGN Linear Guide, Removing Stock Grease: 步骤 5 中的图像 1,1
    • With the ball bearings in a container pour in a little degreaser.
    • Kerosene, Mineral Spirits, or WD-40 Degreasers(not regular WD-40) are all great products you can use. Do not use it on non metal parts. Petroleum-based degreaser can eat away plastic and rubber components.
    • Cleaning the oil off is simple. Put a lid on the container and shake it. When finished remove the balls from the container and set them on a microfiber cloth to try.
    • Degreasers can be harmful to skin. I recommend wearing rubber/latex gloves.
    • Wipe the inside of the metal block and end caps with a microfiber cloth. I use a pipe cleaner to clean the channel.
    询问修复机器人
    添加评论
  5. MGN Linear Guide, Reassembly: 步骤 6 中的图像 1,1
    • On one side reattach the plastic block to the MGN block. Slide in both retaining wires and screw in the rubber end cap.
    • Add a drop of Super Lube into the holes where the ball bearings drop in(this will help prevent them from falling out. Start inserting ball bearings into the hole channel. When they fill up place the second plastic block into the MGN block and attach the retaining clip.
    • Insert the remaining ball bearings into the inner channel. There should be a small gap in between the ball bearings.
    询问修复机器人
    添加评论
  6. MGN Linear Guide, Applying Grease: 步骤 7 中的图像 1,3 MGN Linear Guide, Applying Grease: 步骤 7 中的图像 2,3 MGN Linear Guide, Applying Grease: 步骤 7 中的图像 3,3
    • High viscos(thick) lubrication will prevent the ball bearings from circulating freely. If it's too thin you'll need to re-apply often.
    • I recommend Super Lube 51010. It's an excellent PTFE-based lubricant. 51014, 51004, 51008, 51025 can be used as a substitute. They're the same product but in a different packaging.
    • Shake the bottle well. Apply 1-2 drops into the ball bearings on both sides of the carriage block.
    • If you notice dust and hair collected onto the rubber seal give it a quick wipe with a microfiber cloth. Don't forget to do the opposite side of the block.
    添加评论
终点
取消:我没有完成这个指南。
2等其他人完成本指南。
David Husolo
于06/16/21注册
9,382 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 83
总计 6,058
