跳转到主内容
加入维修社区 - 创建账户
Logitech Webcam Pro 9000 Snapshot Button Replacement
你所需要的
  1. Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: 步骤 1 中的图像 1,2 Logitech Webcam Pro 9000 Snapshot Button Replacement, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
    询问修复机器人
    添加评论
  2. Logitech Webcam Pro 9000 Snapshot Button Replacement: 步骤 2 中的图像 1,2 Logitech Webcam Pro 9000 Snapshot Button Replacement: 步骤 2 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
    询问修复机器人
    添加评论
  3. Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 步骤 3 中的图像 1,3 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 步骤 3 中的图像 2,3 Logitech Webcam Pro 9000 Snapshot Button Replacement, Snapshot button: 步骤 3 中的图像 3,3
    • Grasp the white connector attaching the button chip wire to the motherboard.
    • Grab between the tabs and the socket.
    • Wiggle the connector back and forth to remove it from the connection box
    • Do not worry if you detach the red and black wire connection on the power button.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Cory Davis
于04/14/13注册
236 声望
创作了4篇指南
团队
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
3指南评论
Power button? Does this actually turn the camera on and off? When I push it, it seems to just pause the screen for a moment. I thought maybe it was taking still shots, but I cant seem to find a folder with any in it. I've checked all Logitech's default folder directories. (Trying to figure out what this button does, or can actually be used for.) If you want to turn a webcam off, you usually just unplug them.
Edit: Manual says its a snapshot button, but I'd love for this to start/stop OR pause recording. Hm.....
Harrison - 回复 分享
I've tried to properly update this to make it more accurate, but I'm unsure how the process works. Maybe I submitted it for review? I'm not sure, but my changes have not taken effect, yet.
Harrison - 回复 分享
They were indeed submitted for approval, and have been approved! =)
Sam Goldheart - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 39
总计 2,658
