跳转到主内容
加入维修社区 - 创建账户
Logitech UE Megaboom 4 Battery Replacement
你所需要的
    1. Logitech UE Megaboom 4 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Logitech UE Megaboom 4 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Logitech UE Megaboom 4 Battery Replacement, Battery: 步骤 1 中的图像 3,3
      • Flip your speaker upside down so the charging port side is faced upwards.
      • Take a metal spudger in between the rubber bottom and the mesh case.
      • Work your way around the base of the speaker until the top separates from the case of the speaker.
      • This will take force.
      • Use the metal spudger carefully. Improper use may lead to injury.
      询问修复机器人
      添加评论
    2. Logitech UE Megaboom 4 Battery Replacement: 步骤 2 中的图像 1,1
      • Remove the bottom of the speaker and place it off to the side.
      • Once the glued seal is broken you will be able to pull it off with your hands.
      询问修复机器人
      添加评论
    3. Logitech UE Megaboom 4 Battery Replacement: 步骤 3 中的图像 1,3 Logitech UE Megaboom 4 Battery Replacement: 步骤 3 中的图像 2,3 Logitech UE Megaboom 4 Battery Replacement: 步骤 3 中的图像 3,3
      • Push with your thumbs on the two plastic pieces on the inside of your speaker.
      • The inside components will begin to slide out of the top from the mesh casing.
      询问修复机器人
      添加评论
    4. Logitech UE Megaboom 4 Battery Replacement: 步骤 4 中的图像 1,1
      • The case and internal components of your speaker should now be separated.
      询问修复机器人
      添加评论
    5. Logitech UE Megaboom 4 Battery Replacement: 步骤 5 中的图像 1,3 Logitech UE Megaboom 4 Battery Replacement: 步骤 5 中的图像 2,3 Logitech UE Megaboom 4 Battery Replacement: 步骤 5 中的图像 3,3
      • Pull the battery out with your fingers.
      • When pulling the battery out, you may need to wiggle it a little bit or use a rubber grip on your fingers.
      询问修复机器人
      添加评论
    6. Logitech UE Megaboom 4 Battery Replacement: 步骤 6 中的图像 1,1
      • When installing the new battery, ensure that the battery connector aligns with the connector on the speaker so they don't get damaged.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
2指南评论
ifixt it doesn't have the battery replacement version for the Ultimate Ears - MEGABOOM 4 and only show replacement battery for older model and I think this get confuse for new users in the repair world
Gio Ortegini - 回复 分享
Hi Gio,
Thanks for pointing this out! We’ve removed the link to the incorrect battery and appreciate your help keeping the guide accurate.
Sarah Westberg - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 82
总计 1,063
