跳转到主内容
加入维修社区 - 创建账户
Logitech UE MegaBoom Power Button Replacement
你所需要的
    1. Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 1,3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 2,3 Logitech UE MegaBoom Power Button Replacement, Outer Mesh: 步骤 1 中的图像 3,3
      • Locate the ends of the speaker.
      • Put a plastic opening tool in-between the rubber end and the mesh.
      • Apply a upward force in order to pry open the end.
      • Apply this procedure to the other side as well.
      • Will take force.
      • Using metal tools may permanently mar your device.
      添加评论
    2. Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 1,3 Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 2,3 Logitech UE MegaBoom Power Button Replacement: 步骤 2 中的图像 3,3
      • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
      • You will hear clicks as it pries up, don't worry.
      • Remove all the rubber you pried off.
      添加评论
    3. Logitech UE MegaBoom Power Button Replacement: 步骤 3 中的图像 1,2 Logitech UE MegaBoom Power Button Replacement: 步骤 3 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
      • Work the plastic retainer out of the channel all the way around the speaker.
      • Be gentle, it is easy to damage the fabric.
      • Repeat for other side.
      添加评论
    1. Logitech UE MegaBoom Power Button Replacement, Power Button: 步骤 4 中的图像 1,2 Logitech UE MegaBoom Power Button Replacement, Power Button: 步骤 4 中的图像 2,2
      • Locate the end of the speaker which contains the power button.
      • The circuit board which contains the power button should be visible.
      • Grasp the outer rim of this end cap and pull in an upward motion.
      • This might require some force.
      询问修复机器人
      添加评论
    2. Logitech UE MegaBoom Power Button Replacement: 步骤 5 中的图像 1,1
      • Insert a opening tool between the circuit board and one of the black clips which is holding the board in place.
      • Using the opening tool pry up on the clip allowing the board to be freed. Pry up on the second clip to fully release the board.
      • Using your fingers lift the board out of place.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Cal Poly, Team S9-G2, Banghart Fall 2017 Cal Poly, Team S9-G2, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G2
4 名成员
创作了30篇指南
3指南评论
Will it still be waterproof after repairing?
TechBrush - 回复 分享
that would be a negative unless you really know what you are doing and can waterproof it
Justin Doubikin - 回复 分享
nice piece. i was able to follow the guide and got it right taking out the board. please where can one purchase the power button board. thanks
tony - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 68
总计 5,478
